Introduction: Knex Pistol Without Rubberband
Very simple decently reliable. Takes 5 min to build if your that bad with connects.
shoots on average 15 feet
Pros
small
reload time is short
can hold in sleeve
aim is doorway size at full range
cons
two hands
missfires
Pros
small
can hold in sleeve
cons
two hands
missfires
Step 1: Collect
You will need:
6 green rods
1 blue rod
1 white connector
4 dark grey connectors
4 orange connectors
1 yellow connector
1 yellow rod
1 red/grey rod (I used grey)
6 green rods
1 blue rod
1 white connector
4 orange connectors
1 yellow connector
1 yellow rod
Step 2: 6 Greens & the White Connector
Connect the 6 green rods around the white connector
Step 3: Grey Rod & 2 Orange Connectors
Connect the two orange connectors onto the grey/red rod facing the same way
Step 4: Blue Rod & Yellow Connector
Connect the blue rod to the orange connectors. Then put the yellow connector on either side of the blue rod.
Step 5: Connect
Put the white connector on the side that the yellow connector is on
Step 6: 2 Grey Connectors
Place the two grey connectors so that they hold they white connector to the edge of the grey rod
Step 7: 2 Grey and Yellow Rod
Slip the yellow rod through the grey piece to hold it in place the use the other greys to hold it to make sure it doesn't slip out.
Step 8: 2 Orange
place 2 orange connectors on each side of the yellow rod
Step 9: Shift
Shift them into the nook made by the green rods
Step 10: Align & Fire
Align the yellow connector with the green rod in the middle the push on the end of the blue piece and..... FIRE!
