Knex Pistol With Sear System
Intro: Knex Pistol With Sear System
this is a pretty powerful (20 feet with one #64 rubberband)knex pistol i made using the trigger and sear system in a similar way shown in my previous instructable. The red connectors on the back of the gun aren't in the pic but theyre in the instructions.
Pieces:
Rods:
2 red
1 tan (rigid)
8 blue
15 white
26 green
Connectors:
4 white
2 blue
20 yellow
4 green
14 red
2 light grey
2 orange
11 dark grey clips
2 tan clips
2 special black arm things
3 #64 rubberbands (preferred)
Pieces:
Rods:
2 red
1 tan (rigid)
8 blue
15 white
26 green
Connectors:
4 white
2 blue
20 yellow
4 green
14 red
2 light grey
2 orange
11 dark grey clips
2 tan clips
STEP 1: Body
make 2 of these
STEP 2: Trigger System
From left to right:
Trigger, Sear, and safety
STEP 3: Handle
enter longer description for this step
STEP 4: Trigger Reseter
this is a simple piece that will insure the trigger goes back to its resting position with the addition of a rubberband (later in the instructable)
STEP 5: Barrel
sorry it's so bright pretty simple there's only two blue washers, one on either side, and there's six dark grey connectors 3 on either side.
STEP 6: Firing Pin
easy
STEP 7: Putting It All Together and Rubberband Attachment
READ THIS BEFORE YOU START!!!!!!!!!
For pic 2 and 3 you'll need to attach these pieces (pic 1)where shown dont attach the second dark grey connector yet (it's not letting me put image notes)
In pic 2 the safety is inserted into the (top) half of the gun in the white connector (to the left)in pic 4 put both sides together don't let anything fall out (this may be hard)
Pic 4 shows the rubberband that resets the trigger start from where shown and put the band on the red connectors in the front (you may need to to take the blue rods off by the trigger)
Pic 5,6,7 should be easy and show you where the rubberband for the sear is placed
Pics 8 and 9 show how the barrel is attached with the firing pin in the barrel as well
Finnally step 10 the rubberband on the firing pin (easy)
STEP 8: Loading and Firing
to load the gun all you have to do is stick a rod down the front of the barrel (white or green works best) but anything you can fit will do. After you've loaded the gun pull the firing pin back, the bottom of the tan clip on the firingpin will catch the sear and lock in, now all you have to do is pull the trigger(may require a little force depending on the strngth of the firing pin rubberband)and watch it fly.
144 Comments
~Meme~ 12 years ago
Mine uses less pieces and goes 70ftpls.
bballkidx 12 years ago
everyone here would love to see it post an instructable for it
~Meme~ 12 years ago
https://www.instructables.com/id/Knex-Slingshot-Pistol/
DreadFire3000 13 years ago
charlie-on-our-6 13 years ago
bbbbl 13 years ago
king of knex 13 years ago
moxx 13 years ago
Agorion 13 years ago
https://www.instructables.com/id/Simple-And-Effective-Knex-Gun/
the poodleo 13 years ago
nickster168 14 years ago
smegz 14 years ago
taivo7796 14 years ago
Kevio bro 16 years ago
An Villain 14 years ago
Yukondano2 14 years ago
smattman22 14 years ago
