Introduction: K'nex Spining Jack
Its a classic from the game of Jacks.
Bigger better spins faster and built from K'nex!!
Actually spins
Actually spins
Step 1: Parts
It has a good amount of parts 58 total parts
6 purple connectors
6 blue connectors
3 white connectors
8 green connectors
8 blue rods
24 white rods
1 red rod
1 gray one pined connector
1 brown end cap with the rod coming out of it
6 purple connectors
6 blue connectors
3 white connectors
8 green connectors
8 blue rods
24 white rods
1 red rod
Step 2: Make These
make the pieces below by connecting 2 green connectors to 1 blue rod do this 4 times
Make the pieces below
Step 3: Connect Them
Take all the pieces you just made and connect them at the end of the green connector using a blue rod
Connect the pieces as shown below
Step 4: Add These
Add 2 white rods to each of the green connectors add them to every connector
Check Picture 2 when done
Step 5: Add This
Add a white connector to any one the white rods refer to the picture below for help
Then do the same thing across from the white rod(picture 2)
Step 6: Make This
Take one white connector and add a white rod to each and every pin
make this piece as shown below
Step 7: Make This
Connect the blue and purple connectors as shown below connect them thru the opening
Step 8: Check
Now look at the picture below and make sure you have all the pieces as shown
Step 9: Add These
Add the blue connectors with the purple going thru to the main piece make sure the purple connector pin is facing into the circle
Do this 6 times
Add the Blue and purple pieces as shown below
Do this 6 times
Step 10: Almost Done
Okay now take the white connector piece from step 6 and put the red rod thru the middle then at the other end place the gray connector one the end of the red rod as shown in picture 2
Okay now the most important piece is the brown end cap with the little rod coming out of it.
That has to be connected to the red rod from the side and then slide it down so the brown rod on the end cap goes into one of the inner holes of the white connector (Picture 3)
Step 11: Last Step
Now finally put the white connector piece in the middle of the circle and connect the white rods to the white connectors and purple connectors
and your done. If you did this correctly if should look like this I
V
V
V
V
