Introduction: Knex Inverter Lift
this is a very effective lift type
you can build as high as you want (if you have the pieces) and even use the chain lift too
and there are disadvantages
i don't know how to put a motor on it
lots of pieces
lots of pieces
Step 1: The Lifts
these are the lift you need to make
make as much as you need to make it at the desired height
You'll need (per lift);-
CONNECTORS RODS SPACERS
yellow 5 way 3 yellow 3 blue 12
green 4 way 3 blue 3 grey 6
blue 7 way (3D) 2 white 2
grey 1 way 6
grey 1 way 6
Step 2: The Frame
the frame is quite easy
again just do as the picture says
Step 3: Adding on the Lifts
to add on the the lifts to the frame you need to a 2 grey 1 wat connectors through the rod so the lifts can slide up and down
Step 4: Joining the Lifts
this is very simple to join the lifts
you simply do by adding 2 grey 1 way connectros onto each blue rod( check the pic)
Step 5: Adding the Balls
when it's finished push one up and the other down and keep doing that then the ball will travel upwards
