Introduction: K'nex Spiral Element
About: I've had K'nex as long as i can remember but it wasn't until I was old enough to have a credit card and an eBay account that I started working on much larger scale projects. I've built roller coasters and the…
An exciting element for any knex ball tower.
Video link at https://www.youtube.com/watch?v=XTc5rsT-Lfg
Step 1: Frame
Construct a frame using 12 grey rods and 16 blue connectors. Alternatively you could use purple connectors depending on the situation.
Step 2: The Crossbars
Add the crossbars using grey rods, grey connectors and lots of spacers. Put 2 connectors on each end of the rod and add the spacers as shown in the diagram. Spacing is crucial so if you are using something smaller than a standard knex ball you should use less spacers.
x grey rods
2 grey connectors per rod
lots of spacers
Its a bad photo, yeh?
Step 3: The Crosspieces
Add the crosspieces in the pattern 3-2-3-2....
Step 4: Compiling the Crosspieces
Slide the crosspieces together so that they only just touch. Ensure that the crosspieces all connect together with the pins locking into the rectangular holes in the corresponding pieces as shown in the picture.
(Thats a completely useless photo.  I don't know how enyone could make comething comprehensive from that)
Step 5: Tubing
Wrap the tubing into the spiral ensuring that all the connector pins are used. When you reach the top wrap the tubing around the uppermost crosspieces so that the track is on roughly 45 degrees to allow easy entry for the balls. In the picture I have added an extra length of tubing to make the track smoother as well as two extra crosspieces for support.
approx 1m tubing required
(Is it bending?  YES.  If you can, use some lss-stiff tubing (like the orange stuff))
