Knex Revolver True Trigger
Intro: Knex Revolver True Trigger
ok after i saw syprans idea for the taped up cylinder i couldnt let myself sleep without basing an instructable on it oh and by the way the pictures are crap because i couldnt find a real digital camera so i used my xbox live vision camera and i will probably post an instructable on how to set that up because well yes my internet friends it is a B1@h7 to set up if you dont take the easy way out
STEP 1: Make the Cylinder
same as syprans only half the size 2 silver spacers rolled together make 8 of these put em on the the what sypran used and
STEP 2: Make the Handle
simple and i guess comfortable
STEP 3: Barrel Tip and Front Sight
just make this part
STEP 4: Trigger
STEP 5: Cylinder Platform
ok make sure the red connector faces down and must have those 2 spacers
STEP 6: Inner Barrel
STEP 7: Gather Last Pieces and Firing Pin
ok fixed this u do not need to modf the pieces gather these parts
STEP 8: Assembly
ok attacth the cylinder to the cylinder holder ,that attaches to tip ,tp to top rail ,MAKE SURE U PLACE THE WHITE PIECE THERE, sides go on put trigger in MAKE SURE THAT BAR WITH CLIPS IS ON it keeps the trigger from falling outand the handle u saw the first pic i dont need to take another pic im lazy and hungry
STEP 9: Loading FIring and Ammunition
first just find a good spot for a trigger rubber band and a firing pin rubber band 2nd get ammo take a preferably long rod or any rod that u find almost usless cut it into pieces as big as little green connectors i used a green rod flip 3rd pull back ram rod and open front barrel tip 4 either load te cylinder or replace it i have 2 cylinders so i can easily swap out the empty cylinder with a fresh one 5 close the barrel and shoot on pull back the ram rod change the barrel and pull the trigger i
I give alot of credit to sypran for his genius tape revolver cylinder idea
41 Comments
mberg 12 years ago
rubber man 13 years ago
connor123 14 years ago
PiTBuLL892 14 years ago
feralin 14 years ago
knexologic 14 years ago
firefox0070 14 years ago
dumdum24 14 years ago
tjzx3432 15 years ago
Bwbt1 15 years ago
firefox0070 15 years ago
buthead187 15 years ago
cwskms 15 years ago
happybirthday 15 years ago
Wafflicious 15 years ago
