Introduction: Knex Seaplane
I made this knex plane because I was bored and couldn't think of anything else to do.
The plane is very simple to make and doesn't use many pieces and none of them and cut or sanded.
Im sorry but theres not a parts list to this i took it apart before i had time to make one.
Please comment if you dont understand something im happy to help.
P.S give me good votes
Step 1: Making the Wings
These wings go on top of the plane simple to make!
1. what you are making
2. make two of these
3. What the pieces are
4. the rods connect the two wing parts together
Step 2: Making the Wheels
You could probaly make this part with the first picture its really easy!
2. Make this
3. Make two of these
4. close up
5. another close up
6. attach wheels to main body and your done
2. Make this
4. close up
5. another close up
Step 3: Making Front of the Plane
this is the little red and yellow pieced thing on the front of the plane with the propeller.
2. make the propeller
3. Make these
4. Make these
5. make these
6. make two of these
7. and finnaly make this
8. attach pic 6 and 7 togehter like this
9. put pic 4 on
10. put on pic 5
11 different view of picture 10
12. put pic 3 on
13. add the propeller and attach a grey connecter on the end
3. Make these
4. Make these
5. make these
9. put pic 4 on
10. put on pic 5
12. put pic 3 on
Step 4: Making the Main Body
This is the hardest part of the build
1. this is it, all you gotta do hard right :P
Step 5: Making the Tail
The tail of the plane is quite simple
1. make this..
2. add this on
3. and this
4. different view of picture 2
5. make this
6. make this too
7. different angle of picture 5
8. another view
9. combine 5 and 2 like so
1. make this..
2. add this on
3. and this
5. make this
6. make this too
8. another view
Step 6: Putting It All Together
this part is quite complicated, if you need help with any of this just comment me and ill try to help you as much as I can!
1. attach the main body and the front together
2 - 4 different views of the connection points
5. attach the top tail section to the rear of the main body
6. add the lower tail secton on
7. top view of the tail section
8. close up of the rear rudders
9. underneath view of the tail
10. add on the wheels
11. slighty moved view
12. add these on the sides of the main body
13. slighty moved view
14. finally add on the wings to the top using the rods
15. you are done!!! wippeee :P
