Introduction: Knight Rider Chasing Headlights
The red headlights on the Knight Rider car.
Arduino
6 LED bord with built in 1k Risistors
Step 1:
Attach your led bord with the ground pin adjacent to pin 13
Step 2:
Download following code and enjoy:
const int outPin1 = 13; // Analog output pin that the LED is attached to
const int outPin2 = 12; // Analog output pin that the LED is attached to
const int outPin3 = 11; // Analog output pin that the LED is attached to
const int outPin4 = 10; // Analog output pin that the LED is attached to
const int outPin5 = 9; // Analog output pin that the LED is attached to
const int outPin6 = 8; // Analog output pin that the LED is attached to
void setup() {
pinMode(outPin1, OUTPUT); // set pin 13 as an output
pinMode(outPin2, OUTPUT); // set pin 13 as an output
pinMode(outPin3, OUTPUT); // set pin 13 as an output
pinMode(outPin4, OUTPUT); // set pin 13 as an output
pinMode(outPin5, OUTPUT); // set pin 13 as an output
pinMode(outPin6, OUTPUT); // set pin 13 as an output
void loop() {
// put your main code here, to run repeatedly:
digitalWrite(outPin1, HIGH);
delay(100);
digitalWrite(outPin1, LOW);
digitalWrite(outPin2, HIGH);
delay(100);
digitalWrite(outPin2, LOW);
digitalWrite(outPin3, HIGH);
delay(100);
digitalWrite(outPin3, LOW);
digitalWrite(outPin4, HIGH);
delay(100);
digitalWrite(outPin4, LOW);
digitalWrite(outPin5, HIGH);
delay(100);
digitalWrite(outPin5, LOW );
digitalWrite(outPin6, HIGH);
delay(100);
digitalWrite(outPin6, LOW);
delay(100);
digitalWrite(outPin5, LOW);
delay(100);
delay(100);
delay(100);
delay(100);
