Introduction: Knitting Lessons: Cast on Techniques
All knitting starts with casting on. This creates loops on the needle which will become the first row of stitches. Here I present four cast on techniques which are the most commonly used.
These techniques include:
Single Cast On
Longtail Cast On
Knitted Cast On
Cable Cast On
I recommend learning the Single Cast On and Longtail Cast On techniques first. The longtail is my favorite; once you get the hang of it it is super easy and makes a nice edge. I would wait to learn the knit stitch before you learn the Knitted Cast On and Cable Cast On. It is much simpler once you are proficient at the knit stitch.
I suggest using wooden needles when learning how to knit.
For more knitting tutorials visit my page: Carleyy.
Step 1: Single Cast On
- Start by making a loop with the yarn.
- Bring the yarn through the loop, creating another loop with a knot at the end
- Slide slip knot onto needle. Pull yarn to tighten knot
- Wrap the working yarn (yarn connected to the ball of yarn) around your thumb so you have a loop around your thumb.
- Bring the needle under and up through the loop around your thumb
- Remove your thumb from the loop and pull the yarn
- Continue from step 2 until you have desired number of stitches casted on
Step 2: Longtail Cast On
- Drape the tail over your thumb and pointer finger on your left hand.
- Catch it in between your pointer and middle finger.
- Catch the yarn connected to the ball against your palm with your pinky and ring fingers.
- Take the needle in your right hand. Place it on top of the yarn between your thumb and pointer finger.
- Draw the yarn towards you with the needle. You should see a loop of yarn around your thumb.
- Bring the needle under the outer piece of yarn next to your thumb and up through the loop.
- Bring the needle back towards your pointer finger.
- Bring the needle over the yarn connected to your pointer finger and then under back towards the thumb.
- Drop the head of the needle back down through the loop around your thumb.
- Release your thumb from the loop and pull the yarn.
- Repeat from step 6 until you have the desired number of stitches casted on.
Step 3: Knit Cast On
- Make a slip knot and put it on your needle. Hold this needle in your left hand and take the second needle in your right hand.
- Pass the needle in the right hand through the loop on the left needle and bring the right needle under the left needle.
- With your left hand, wrap the working yarn around your left hand needle.
- Bring the right needle back through the loop on the left needle.
- Now you have a loop around your right needle. Turn the loop and drop it on to the left needle and release the right needle from the loop .
- Pull the yarn and you have two stitches casted on.
- To continue, repeat from step 2.
Step 4: Cable Cast On
- For the first two stitches, use instructions for knitted cast on.
- Once you have two stitches casted on. Take your right needle and put it in between the two stitches by bringing it under the left needle and through the yarn that connects the two stitches.
- Wrap the working yarn around the right needle.
- Bring the right needle back through the loops.
- Pull the yarn. You should have two stitches casted on.
Holiday Gifts Contest
1 Person Made This Project!
- TrissS made it!
19 Comments
2 years ago
Thank you so much to whoever made this video. It was very helpful! I have a few pictures down below. Look at the pictures please and tell me if it should look like this. There is a few holes its not perfect, but please tell me if I am on the right track and how I messed up(if I did) thank you so much for your time!
Reply 1 year ago
Love it good job. Better than what I can do!
Reply 2 years ago
That looks pretty good! The stitches look nice and even :) The type of stitch shown in the square is a garter stitch and it's very stretchy. Alternating rows of purl stitch and knit stitch will create a stockinette, which is the same as most shirts tho those stitches are super tiny and hard to see
2 years ago on Introduction
Rozbig.ir like
Tip 2 years ago
In the last 2 videos (knit cast on and cable cast on) the demonstrator is using the yarn tail instead of the working yarn to make new stitches. Working yarn is the end attached to the ball of yarn.
Question 3 years ago on Introduction
How many stitches for a child's slippers
Question 4 years ago on Introduction
How much yarn do you need to allow for the tail when casting on with single cast on
6 years ago
Been trying long tail cast on for months!!! Your video and instructions have finallly helped me see the light
6 years ago
Sorry wrong person :)
6 years ago
Thanks for following me
6 years ago
I love the cable cast on but wonder where it would be used
6 years ago
it took me a few tries and stop and start but I finally got the knit and the cable. Now on to my first real project. Then on to the scariest, cables. Finally the most terreifying, clothes...
9 years ago on Introduction
This really makes knitting look easy!! I think the video helped the most; thank you so much for that. I do echo katzenmama's question of "what would be the reason for choosing one technique over another?" Now I'm off to Walmart to buy 2 knitting needles and a small amount of yarn to practice.
Thank you for sharing this fine Instructable ;) I have for a long time want to learn how to knit. I like to use my hands, and like to sew. Soon I will get myself a sewing machine. Its fun to learn a little of this and that, and use it together in an art collage. Maybe sew with metal wire..? A special wire of course..
Kjetil
9 years ago
Still having trouble casting on I don't get how to do the first casting on it just makes a loop if you could post a video I would very appreciate it. Thanks
10 years ago on Step 2
Thank you for all of your knitting lessons. I appreciate how thoroughly you documented each step both with photos and written instructions. I also greatly appreciate that you used verbal instructions in your videos, rather than simply showing the techniques. The combination of photo, text, video and verbal instructions have made learning to knit very easy. (Now if only I could do it without dropping stitches, etc. lol ) I started with the single cast on, as it seemed to be the easiest casting on method to learn, and have now learned the knit stitch and the purl stitch through your tutorials. I also finished your casting (binding) off lesson, and am now returning to the cast-on lessons to learn the other casting on techniques.
My question for you is: what would be the reason for choosing one technique over another? Is there a hierarchy of superiority between the various methods? Would the decision be based on the type of project one is doing?
Thanks! Kati
11 years ago on Introduction
omg thank u so much yours is the only one that makes sense!!!!
12 years ago on Introduction
I have tried so many different tutorials on casting on even other videos, but I must say yours is the only one that was through enough for me to understand how to do it!
Thank you so very much.
I was having trouble learning to cast on, but I have to say the single cast on video was a huge help. I love that it was filmed first person, made it so much easier to understand.
