Introduction: Knock, Knock, Neo.
Everyone has made at least one time the Matrix batch file (the one that shows random numbers in bat file).
So I thought that I might make a file that does something different.
You might remember the scene where Neo is contacted via his PC screen.
So this bat file tries to create the same effect.
Step 1:
Step 2: Code
Copy and paste this code in Notepad
@echo off
title Connecting.....
echo.
set count=0
:1
if "%count%"=="300" goto 2
set /a count+=1
goto 1
:2
echo W
set count=0
:3
if "%count%"=="100" goto 4
set /a count+=1
goto 3
:4
cls
echo.
echo Wa
set count=0
:5
if "%count%"=="100" goto 6
set /a count+=1
goto 5
:6
cls
echo.
echo Wak
set count=0
:7
if "%count%"=="100" goto 8
set /a count+=1
goto 7
:8
cls
echo.
echo Wake
set count=0
:9
if "%count%"=="100" goto 10
set /a count+=1
goto 9
:10
cls
echo.
echo Wake u
set count=0
:11
if "%count%"=="100" goto 12
set /a count+=1
goto 11
:12
cls
echo.
echo Wake up
set count=0
:13
if "%count%"=="100" goto 14
set /a count+=1
goto 13
:14
cls
echo.
echo Wake up,
set count=0
:15
if "%count%"=="100" goto 16
set /a count+=1
goto 15
:16
cls
echo.
echo Wake up, N
set count=0
:17
if "%count%"=="100" goto 18
set /a count+=1
goto 17
:18
cls
echo.
echo Wake up, Ne
set count=0
:19
if "%count%"=="100" goto 20
set /a count+=1
goto 19
:20
cls
echo.
echo Wake up, Neo
set count=0
:21
if "%count%"=="100" goto 22
set /a count+=1
goto 21
:22
cls
echo.
echo Wake up, Neo.
set count=0
:23
if "%count%"=="100" goto 24
set /a count+=1
goto 23
:24
cls
echo.
echo Wake up, Neo..
set count=0
:25
if "%count%"=="100" goto 26
set /a count+=1
goto 25
:26
cls
echo.
echo Wake up, Neo...
set count=0
:27
if "%count%"=="800" goto 28
set /a count+=1
goto 27
:28
cls
echo.
color 0a
echo T
set count=0
:29
if "%count%"=="50" goto 30
set /a count+=1
goto 29
:30
cls
echo.
echo Th
set count=0
:31
if "%count%"=="50" goto 32
set /a count+=1
goto 31
:32
cls
echo.
echo The
set count=0
:31
set /a count+=1
goto 31
:32
cls
echo.
echo The M
set count=0
:33
if "%count%"=="50" goto 34
set /a count+=1
goto 33
:34
cls
echo.
echo The Ma
set count=0
:35
if "%count%"=="50" goto 36
set /a count+=1
goto 35
:36
cls
echo.
echo The Mat
set count=0
:37
if "%count%"=="50" goto 38
set /a count+=1
goto 37
:38
cls
echo.
echo The Matr
set count=0
:39
if "%count%"=="50" goto 40
set /a count+=1
goto 39
:40
cls
echo.
echo The Matr
set count=0
:41
if "%count%"=="50" goto 42
set /a count+=1
goto 41
:42
cls
echo.
echo The Matri
set count=0
:43
if "%count%"=="50" goto 44
set /a count+=1
goto 43
:44
cls
echo.
echo The Matrix
set count=0
:45
if "%count%"=="50" goto 46
set /a count+=1
goto 45
:46
cls
echo.
echo The Matrix h
set count=0
:47
if "%count%"=="50" goto 48
set /a count+=1
goto 47
:48
cls
echo.
echo The Matrix ha
set count=0
:49
if "%count%"=="50" goto 50
set /a count+=1
goto 49
:50
cls
echo.
echo The Matrix has
set count=0
:51
if "%count%"=="50" goto 52
set /a count+=1
goto 51
:52
cls
echo.
echo The Matrix has y
set count=0
:53
if "%count%"=="50" goto 54
set /a count+=1
goto 53
:54
cls
echo.
echo The Matrix has yo
set count=0
:55
if "%count%"=="50" goto 56
set /a count+=1
goto 55
:56
cls
echo.
echo The Matrix has you
set count=0
:57
if "%count%"=="50" goto 58
set /a count+=1
goto 57
:58
cls
echo.
echo The Matrix has you.
set count=0
:59
if "%count%"=="50" goto 60
set /a count+=1
goto 59
:60
cls
echo.
echo The Matrix has you..
set count=0
:61
if "%count%"=="50" goto 62
set /a count+=1
goto 61
:62
cls
echo.
echo The Matrix has you...
set count=0
:63
if "%count%"=="500" goto 64
set /a count+=1
goto 63
:64
cls
echo.
echo F
set count=0
:65
if "%count%"=="50" goto 66
set /a count+=1
goto 65
:66
cls
echo.
echo Fo
set count=0
:67
if "%count%"=="50" goto 68
set /a count+=1
goto 67
:68
cls
echo.
echo Fol
set count=0
:69
if "%count%"=="50" goto 70
set /a count+=1
goto 69
:70
cls
echo.
echo Foll
set count=0
:71
if "%count%"=="50" goto 72
set /a count+=1
goto 71
:72
cls
echo.
echo Follo
set count=0
:71
set /a count+=1
goto 71
:72
cls
echo.
echo Follow
set count=0
:73
if "%count%"=="50" goto 74
set /a count+=1
goto 73
:74
cls
echo.
echo Follow t
set count=0
:75
if "%count%"=="50" goto 76
set /a count+=1
goto 75
:76
cls
echo.
echo Follow th
set count=0
:77
if "%count%"=="50" goto 78
set /a count+=1
goto 77
:78
cls
echo.
echo Follow the
set count=0
:79
if "%count%"=="50" goto 80
set /a count+=1
goto 79
:80
cls
echo.
echo Follow the w
set count=0
:81
if "%count%"=="50" goto 82
set /a count+=1
goto 81
:82
cls
echo.
echo Follow the wh
set count=0
:83
if "%count%"=="50" goto 84
set /a count+=1
goto 83
:84
cls
echo.
echo Follow the whi
set count=0
:85
if "%count%"=="50" goto 86
set /a count+=1
goto 85
:86
cls
echo.
echo Follow the whit
set count=0
:87
if "%count%"=="50" goto 88
set /a count+=1
goto 87
:88
cls
echo.
echo Follow the white
set count=0
:89
if "%count%"=="50" goto 90
set /a count+=1
goto 89
:90
cls
echo.
echo Follow the white r
set count=0
:91
if "%count%"=="50" goto 92
set /a count+=1
goto 91
:92
cls
echo.
echo Follow the white ra
set count=0
:93
if "%count%"=="50" goto 94
set /a count+=1
goto 93
:94
cls
echo.
echo Follow the white rab
set count=0
:95
if "%count%"=="50" goto 96
set /a count+=1
goto 95
:96
cls
echo.
echo Follow the white rabb
set count=0
:97
if "%count%"=="50" goto 98
set /a count+=1
goto 97
:98
cls
echo.
echo Follow the white rabbi
set count=0
:99
if "%count%"=="50" goto 100
set /a count+=1
goto 99
:100
cls
echo.
echo Follow the white rabbit
set count=0
:101
if "%count%"=="50" goto 102
set /a count+=1
goto 101
:102
cls
echo.
echo Follow the white rabbit.
set count=0
:103
if "%count%"=="400" goto 104
set /a count+=1
goto 103
:104
cls
echo.
echo Knock, knock, Neo.
set count=0
:105
if "%count%"=="600" goto 106
set /a count+=1
goto 105
:106
exit
Save it as anything.bat and run it....
@echo off
echo.
set count=0
:1
set /a count+=1
goto 1
:2
echo W
set count=0
:3
set /a count+=1
goto 3
:4
cls
echo.
echo Wa
set count=0
:5
set /a count+=1
goto 5
:6
cls
echo.
echo Wak
set count=0
:7
set /a count+=1
goto 7
:8
cls
echo.
echo Wake
set count=0
:9
set /a count+=1
goto 9
:10
cls
echo.
echo Wake u
set count=0
:11
set /a count+=1
goto 11
:12
cls
echo.
echo Wake up
set count=0
:13
set /a count+=1
goto 13
:14
cls
echo.
echo Wake up,
set count=0
:15
set /a count+=1
goto 15
:16
cls
echo.
echo Wake up, N
set count=0
:17
set /a count+=1
goto 17
:18
cls
echo.
echo Wake up, Ne
set count=0
:19
set /a count+=1
goto 19
:20
cls
echo.
echo Wake up, Neo
set count=0
:21
set /a count+=1
goto 21
:22
cls
echo.
echo Wake up, Neo.
set count=0
:23
set /a count+=1
goto 23
:24
cls
echo.
echo Wake up, Neo..
set count=0
:25
set /a count+=1
goto 25
:26
cls
echo.
set count=0
:27
set /a count+=1
goto 27
:28
cls
echo.
color 0a
echo T
set count=0
:29
set /a count+=1
goto 29
:30
cls
echo.
echo Th
set count=0
:31
set /a count+=1
goto 31
:32
cls
echo.
echo The
set count=0
:31
set /a count+=1
goto 31
:32
cls
echo.
echo The M
set count=0
:33
set /a count+=1
goto 33
:34
cls
echo.
echo The Ma
set count=0
:35
set /a count+=1
goto 35
:36
cls
echo.
echo The Mat
set count=0
:37
set /a count+=1
goto 37
:38
cls
echo.
echo The Matr
set count=0
:39
set /a count+=1
goto 39
:40
cls
echo.
echo The Matr
set count=0
:41
set /a count+=1
goto 41
:42
cls
echo.
echo The Matri
set count=0
:43
set /a count+=1
goto 43
:44
cls
echo.
echo The Matrix
set count=0
:45
set /a count+=1
goto 45
:46
cls
echo.
echo The Matrix h
set count=0
:47
set /a count+=1
goto 47
:48
cls
echo.
echo The Matrix ha
set count=0
:49
set /a count+=1
goto 49
:50
cls
echo.
echo The Matrix has
set count=0
:51
set /a count+=1
goto 51
:52
cls
echo.
set count=0
:53
set /a count+=1
goto 53
:54
cls
echo.
set count=0
:55
set /a count+=1
goto 55
:56
cls
echo.
set count=0
:57
set /a count+=1
goto 57
:58
cls
echo.
set count=0
:59
set /a count+=1
goto 59
:60
cls
echo.
set count=0
:61
set /a count+=1
goto 61
:62
cls
echo.
set count=0
:63
set /a count+=1
goto 63
:64
cls
echo.
echo F
set count=0
:65
set /a count+=1
goto 65
:66
cls
echo.
echo Fo
set count=0
:67
set /a count+=1
goto 67
:68
cls
echo.
echo Fol
set count=0
:69
set /a count+=1
goto 69
:70
cls
echo.
echo Foll
set count=0
:71
set /a count+=1
goto 71
:72
cls
echo.
echo Follo
set count=0
:71
set /a count+=1
goto 71
:72
cls
echo.
echo Follow
set count=0
:73
set /a count+=1
goto 73
:74
cls
echo.
echo Follow t
set count=0
:75
set /a count+=1
goto 75
:76
cls
echo.
echo Follow th
set count=0
:77
set /a count+=1
goto 77
:78
cls
echo.
echo Follow the
set count=0
:79
set /a count+=1
goto 79
:80
cls
echo.
echo Follow the w
set count=0
:81
set /a count+=1
goto 81
:82
cls
echo.
echo Follow the wh
set count=0
:83
set /a count+=1
goto 83
:84
cls
echo.
echo Follow the whi
set count=0
:85
set /a count+=1
goto 85
:86
cls
echo.
set count=0
:87
set /a count+=1
goto 87
:88
cls
echo.
set count=0
:89
set /a count+=1
goto 89
:90
cls
echo.
set count=0
:91
set /a count+=1
goto 91
:92
cls
echo.
set count=0
:93
set /a count+=1
goto 93
:94
cls
echo.
set count=0
:95
set /a count+=1
goto 95
:96
cls
echo.
set count=0
:97
set /a count+=1
goto 97
:98
cls
echo.
set count=0
:99
set /a count+=1
goto 99
:100
cls
echo.
set count=0
:101
set /a count+=1
goto 101
:102
cls
echo.
set count=0
:103
set /a count+=1
goto 103
:104
cls
echo.
set count=0
:105
set /a count+=1
goto 105
:106
exit
Step 3:
Yeah I know that the code is not hitech and many of you might have created much better codes for this, but mine is the easiest and safest.
You can also change the text as per your wish.
Enjoy.....
Enjoy.....
