Introduction: Komorebi Tree Lamp
This beautiful lamp is simple and easy to make! Just follow our step by step instructions to make one of your very own.
Step 1: Materials
Old working lamp that you do not mind cutting, green lamp shade, brown fabric, wire, soldering iron, and solder.
Step 2:
Separate metal of the lamp shade from all remaining materials. (Fabric, glue, etc)
Step 3:
Find seam of the fabric on the lamp shade and cut along it
Step 4:
Cut a ring into the fabric, with a box cutter, at top and bottom of lamp shade, take precaution if you ring glue. *Do not rush this step.
Step 5:
Connect the base and top piece with the metal coat hanger, it does not have to be symatrical.
Step 6:
Make a dome on the top but leave plenty of room for the bulb to be removed. We recommend a triangular shape.
Step 7:
Using stiff wire, make rib shapes on the side.
Step 8:
Using flexible wire wrap the lamp support sides in a zig-zag design.
Step 9:
Repeat what you did to the side but on the top of the dome.
Step 10:
Spray paint the bottom pieces brown.
Step 11:
Add cardboard to the the top to cover the place where the lightbulb will sit.
Step 12:
Add a cardboard paper towel roll to the base of the lamp. This will be the trunk. Spray paint this.
Step 13:
After paint dries, cut the left over fabric into small pieces and glue it onto the metal frame in any pattern you like.
Step 14:
Once your glue is complete, you have your tree!
