Kool Aid Dyeing for Lace
Intro: Kool Aid Dyeing for Lace
I kept looking for a tutorial for kool aid lace dyeing,but I couldn't find any, so I decided to make my own.
STEP 1: Cut Your Lace
Cut you lace to the desired length you want,unless you want it all the same color. I am going to make a baby headband with my lace so I cut mine to 14 inches.
STEP 2: Choose Your Kool Aid
For this piece of lace I chose grape and blue raspberry. (the blue is very pretty by itself too, as you can see in the first picture)
STEP 3: Soak Your Lace
I use hot water, but room temperature water should be fine too. Mix in just a little bit of your kool aid (unless you are dyeing more than just a few inches). Then put your lace in. I always hold down the lace with fork so it stays completely submerged.
STEP 4: Remove Your Lace
Once the lace is the color that you want, remove it from the kool aid water and rinse in clean warm water. Once rinsed lay out on a paper towel to dry.
STEP 5: Finish
Now you have lace that not only is pretty, but smells like your favorite kool aid. :P
7 Comments
sschlichter 9 years ago
this is an awesome idea! i have been searching high and low for a safe way to dye nylon lace on a vintage wedding dress. now i know exactly what i'll do!!
BluScoutMama 12 years ago
you actually have to add sugar to the kool-aid when making it to drink, so i doubt it would have a sticky scratchy effect if you just used the packet to dye..
teddybear101 12 years ago
saosport 10 years ago
Penolopy Bulnick 12 years ago
