Introduction: Kumiko Lantern
Hey Guys! I made a kumiko lantern for my project in shop class.
The Materials you need is
- BassWood
- Any type of wood for frame (i used walnut wood)
- Paper
Step 1: Make the Kumiko
The Kumiko is made out of basswood, the panels are 4 and a half.
Cut the access out
Step 2: The Legs and Stretchers
For the legs i cut it with the bandsaw and chiseled it with a mallet. Same as with the stretchers in the pictures above. You can do this with a table saw also.
The Legs are by 3/4 x 3/4 x 7 1/4. The cross Lap is 1/2 and you have to measure it with a ruler to mark it and cut it with the bandsaw.
If you don't understand the plans, here is a link that i used to make the lantern https://www.bikecitywoodworks.com/mini-shoji-lante...
Please support them.
Step 3: Hot Glue the Kumiko With Paper
I just got a sheet of printed paper and cover one side and hot glued it for decoration.
use a real sheets for candles if you do put a candle in it.
Step 4: Put It Together!
When your finished, everything should be tightly fit. If not, just sand the stretchers and then you have your kumiko finished!
