Introduction: LAB BENCH TOOL HOLDER
HELLO AND WELCOME BACK !!!
So we all know that there are some basic tools that must be handy to keep in our homes or offices and especially for those into electronics need them quite often .
So in the article we will create a small lab bench tool holder that is not only perfect but also size compact and handy to have .
So let's start with the build !.!.!.!.!
Step 1: FIRST WATCH THE VIDOE FOR BETTER UNDERSTANDING
First watch the video for better understanding and visualization !!
And one more request if you like the video please subscribe to my YouTube channel :
Thank you !!
now back to the article
Step 2: IDEA OF BUILDING THE PROJECT
Basically I have a messy room and if I need on tool I have to find it for 10 minutes . Sometimes if the search was complete earlier the other tool might fall down and the same time would go away for securing them to a safe place .
Anyways so I thought why not to build a tool holder for the tools I use in everyday life .
Step 3: BUILDING THE BODY
Firstly I took around 4mm thickness plywood . Marked a measurement of 40cm in length and 8 cm in breath
After that was done I started slaughtering 2 pieces of wood of same dimensions each .
Then i took a rather good looking square shaped basket (picked up from the scrap) as the base of Tool Holder which has a hole at each corner .
Step 4: FIXING THE BASE
Then I took a PVC pipe sliced two pieces of same height about 20cm and other pair of about 15 cm .
Furnished them using a sand paper .Finally glued them on the two wood piece and finally drilled holes according to the dimensions of each tool .
Step 5: TOOLS INVOLVED (FRONT PANEL)
First and foremost are the screwdrivers of different tips . Second there is a knife (no harm intended) So let me clear it up knife is used to open up spaces where our finger nails can't reach .
Third are the scissors
and then some pliers .
A troch which is quite handy tool to keep in emergency situations and for electronic use like looking at the part no. of the components .
Nut bolt opener the one one most widely used Some tapes like electrical tapes , Kapton tapes , cello tapes and some glittery tapes .
There is also an electrical tester and some arrows to make it look good.
Step 6: TOOLS INVOLVED (BACK PANELS)
Then on the other side there is Stapler Some solder wire . solder wick , desolder pump and some solder beads which are quite useful .
Glues ,sand paper , different types of cables like TYPE A ,TYPE B ,TYPE C , and some micro usb cables
And finally a continuity tester which is very important as well .
Step 7: TOOLS INVOLVED (INSIDE)
Inside there is soldering Iron which is the necessity for any electronic beginner
A glue gun which is also quite good .
Some stationary stuffs
AND the most expensive and useful ones A Vernier caliper and a magnifying glass
