Introduction: LAMP/EMAIL Server With Login/password on a Raspberry PI 2
This Instructable will walk you through the process of
1. Adding Raspbain to the Raspberry PI 2
2. Installing the LAMP server
3. Installing the email server
4. downloading and setup of the login/password process
5. setting up the MySQL database
Step 1: Install Raspbian on the Raspberry PI 2
This tutorial will be using a Debian version of Linux. Raspbian is the operation system used on the Raspberry PI 2. Either Install Raspbian from the start or NOOBS and then choose Raspbian in the installation process. These links will provide instructions on how to install Raspbian or NOOBS.
Raspbian
https://www.raspberrypi.org/documentation/installa...
NOOBS
Step 2: Installing a LAMP Server
1. First update your system
sudo apt-get update
sudo apt-get upgrade
2. To install Apache from the Terminal type these commands:
sudo apt-get update
sudo apt-get install apache2
3. To install MySQL from the Terminal type these commands:
sudo apt-get install mysql-server
sudo apt-get install php5-mysql
4. To install PHP from the Terminal type these commands:
5. Restart server
sudo /etc/init.d/apache2 restart
6. Check to make sure the web server is up type in a web browser:
localhost
You should see the image attached to this step on your browser!!!!!
Step 3: Installing a Mail Server
1. first update system
sudo apt-get update
2, install sendmail
sudo apt-get install sendmail
3. Configure
sudo sendmailconfig
4. use a text editor to open /ect/hosts
sudo nano /etc/hosts or sudo vim /etc/hosts
and add the following line to the top of the file and save
127.0.0.1 localhost localhost.localdomain your_domain_name_here.com
comment out any duplicate lines
5. Restart apache
sudo service apache2 restart or sudo /etc/init.d/apache2 restart
Step 4: Adding the Login/password to Web Server
1. Download open source code from link
http://www.html-form-guide.com/php-form/php-regist...
2. move everything that is in source folder to /var/www/html
enter cd /var/www/html/ in the terminal
then sudo mkdir include scripts style
then cd until you are in the simfatic-RegistrationForm-dc288ct directory
then use the move as root all folders and files in source to /var/www/html/
placing the files in include ,scripts and style in to the same folders that we just made in /var/www/html/
Follow the Read me to make sure the setup of the login/password process is complete.
Step 5: MySQL Set Up for Login/password
You will need to set up MySQL
from the command line in the terminal mysql -u root -p
follow promps and make sure to setup root password
once in the database use create database NameofDatabase
Use this Information when updating the membersite_config.php in the include folder at /var/www/html/
