Introduction: LCD Display Protection Foil
Simple and cheap LCD display protection foil
Do you have fingerprints on your display? - Then this is the solution for you!
Step 1: Solution 1: Use a Self-adhesive Foil
Solution 1: Use a self-adhesive Foil
NOTE: Check also Solution 2 first, before destroy you LCD display!
First try to do some experiments. If you can remove again the foil easy.
Buy a simple foil.
Cut the size you need.
Place it on display.
(More pic will follow, my 2nd cam is not ready for to take a picture right now.)
Buy a simple foil.
Step 2: Solution 2: Use a *non* Self-adhesive Foil
Solution 2: Use a *non* self-adhesive Foil
I did not tried out this solution. But it works :-)
The foil must be totally transparent.
1. Cut off the correct size.
2. Use some transparent tape to fix the foil.
