Introduction: LEARN ULTRASONIC AND SERVO CIRCUIT USING TINKERCAD
go nuts and learn about ultrasonic and servo
All you need is a computer and internet connection for this tutorial
Step 1:
On the home page click on new and select circuit.
Step 2:
now you are here on the workspace. Use the search bar to search for the components(breadboard,arduino,ultrasonic,servo) just hold and drag it
Step 3:
both servo and ultrasonic has 3 pins the 2 pins ins for the ground and power the third is for signal connect it to the arduino any number will work.
Step 4:
CODE:
#include <Servo.h>
int distance = 0;
Servo servo_3;
long readUltrasonicDistance(int triggerPin, int echoPin)
  pinMode(triggerPin, OUTPUT);  // Clear the trigger
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  // Sets the trigger pin to HIGH state for 10 microseconds
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  pinMode(echoPin, INPUT);
  // Reads the echo pin, and returns the sound wave travel time in microseconds
  return pulseIn(echoPin, HIGH);
void setup()
  servo_3.attach(3, 500, 2500);
void loop()
  servo_3.write(180);
  distance = 0.01723 * readUltrasonicDistance(4, 4);
  if (distance <= 100) {
    servo_3.write(90);
    delay(3000); // Wait for 3000 millisecond(s)
    servo_3.write(180);
  servo_3.write(180);
Step 5:
logic:
the servo position at 180 degrees once the ultrasonic sensor distance is greater than equal to 100 degrees the servo position will change to 90 degrees and after for 3 sec it will go back to 180 degrees
