Introduction: LED ANIMATED CHRISTMAS TREE WITH CARD MUSIC MODULE-sapin De Noël Musical
In the Eighties ELEKTOR published in its review a small twinkling Christmas tree, I took as a starting point this idea to carry out that which will follow....
This little Christmas tree is 9 cm high and requires no programing, the animation of LED uses a single IC, the module for the melody need an old musical Christmas card.
all schemes and doc are in a ZIP file at the end of this instructable
I do not know English very well if you find mistakes in this instructable please leave me a message with the correction
Dans les années 80 ELEKTOR a publié dans sa revue un petit sapin de Noël clignotant ,je me suis inspiré de cette idée pour réaliser celui qui va suivre cet instructable est en Anglais mais dans le ZIP qui contient les schémas et les docs est il y a l' Anglais et le Français....
Ce petit sapin de Noël mesure 9 cm de haut, et ne demande pas de programmation, l'animation des led utilise un seul CI, pour la mélodie on utilise le module d'une ancienne carte de Noël musicale.
Step 1: USED EQUIPMENT: (found in Your Country' Stores Electronic Components )
epoxy presensitized 150x100mm (PCB)
iron solder and soldering 1mm diameter
0.8 mm drill and forest
cutter (to clean the burrs between tracks)
wirecutters
acetone (cleaning the PCBafter engraving)
Saw-metal compounds and small fine file (flat or triangular)
UV platesetter (to insolated the presensitized PCB )
developer (for exposed PCB)
ferric chloride (for the final burning of thePCB)
recipents plastic gloves and goggles
COMPONENTS:
8 x 3mm LED (different colors as you lake)
1 x IC CD4060 (CMOS 14 Stage Ripple-Carry Binary Counter/Divider and Oscillator)
1 x 14-pin IC holder double type lyre (for easy folding pin)
resistors (all of 1/4 or 1/2 Watt)
6 x 560 Ohms ( to 560 up to 1000 Ohms it depends on the brightness and battery life you want )
1 x 1 Kohm
1 x 10 Ohms
1 x 33 Ohms
1 x 100 Ohms
capacitors:
1 x 10 uF 16 or 25 Volts (to 10uF up to 33uf)
1 x 100nF (to 100nF up to 220nF it depends on the blink rate you want )
diodes:
1 x 1N4148 (or 1N914)
1 x Zener 3,3Volts
various:
some Christmas picture
Christmas picture (I have attached a print-ready)
1 x 9 volt battery or a small 9 volt block (filtered and regulated)
like this:
WARNING: If you use the old adapter (with adjustable voltage of 3 to 12 Volt) must use 7.5 Volts switch because this type of adapter is not regulated and the voltage is higher)
Software used :
free GPL Kicad
POWERING THE TREE :
Power is supplied with a 9 Volts battery or rechargeable NiMH 8.2 Volts .
You can also work with a 9 Volt power supply output in this case it is necessary to remove the old battery to get the connector and to solder the son of exit 9 -volt power supply to this connector in the + and - .
I tested the 9V battery of the tree with activated musical module, it only lasts 2 to 3 days, I recommend the power supply unit if you use it in your home
Step 2: ELECTRONIC EXPLANATION:
Schematic :
This LED tree is made around a 14-stage binary counter the CD4060 , the oscillator used pins 9 10 and 11 and the capacitor used for this oscillator can take values to 100nF 220nF according to the desired rate of flashing for LEDs see the schematic.
The formula of computation of the oscillator is the following one :Fosc = 1 / (2,3xR9xC1)
R9 = 33000 Ohms(33K) C1 = 0,0000001 Farad(100nF) => Fosc = 1 / (33000 x0,0000001) = 303 Hertz
the output Q4 was 303/4 = 75.7 Hz Q5 was 303/5 = 60.6 Hz ect ....
the resistor R10 should be between 2 and 10 times R9
There is also possible to connect a music module ( recovered from a Christmas card ) these modules work with two 1.5 volt button battery connected in series or battery 3V type CR2016 or CR2032 for these models a 3.3 volt zener diode and a resistance of 56 ohms or 5.1 volts and a resistance of 39 Ohms used to adjust the voltage of the 9V battery musical module .
Some works with a 1.5 volt battery and a small tip , it is possible with the same 9 volt battery for it
I combined three 1N4148 diodes in series with a resistor 10KOhms the voltage drop of a diode is approximately 0.6 Volts , the addition of 10 microfarad capacitor acts as a reservoir.
In this instructable , I described the model using a musical module 3.3 Volts . , The fourth diode 1N4148 is a power actuator .
All components except the LEDs are soldered copper side the procedure is as follows: CI to support the resistance of the pin musical module , capacitor , diodes and bend the legs to the horizontal , cut to length and weld like CMS , weld pressure 9V (without the sheath ) and the shunt supply 4060, solder the capacitor 10 mF ( upside down) on the + and - terminals of the power of music module.
Glue the decorative side component ( I have attached a model) and the varnish , then drill and solder the LEDs.
CAUTION: Do not forget the shunts (red wire on the screenshoot) that connects the battery to the + CI 4060
for those who do not want to use Kicad, here is the PCB (mirrored)
Just print it on transparent ink jet or laser.
attention should be writing upside down on the transparent
Then you tape it on the PCB side inked on copper sensitized
and exposing with UV platesetter
Tip: If you use an inkjet, it is best to make two transparent
and tape them together, overlapping carefully, it gives better results in the burning of PCB.
see the following pictures:
Step 3: Some Images and Screenshots of the Finished Christmas Tree:
THE LINKS :
some PDF Guides :
Understanding and Interpreting Standard-Logic Data Sheets :
http://www.ti.com/lit/an/szza036b/szza036b.pdf
Logic Guide:
http://www.ti.com/lit/sg/sdyu001z/sdyu001z.pdf
CD4060 Datasheet :
http://www.alldatasheet.com/datasheet-pdf/pdf/26880/TI/CD4060.html
Kicad and some library and video at these links :
http://iut-tice.ujf-grenoble.fr/kicad/
http://www.kicad-pcb.org/display/KICAD/KiCad+EDA+Software+Suite
http://www.kicadlib.org/
https://www.youtube.com/watch?v=rkQ0nVX1q1k
some PDF Guides :
Logic Guide:
CD4060 Datasheet :
Step 4: VIDEO and ZIPPED Project
I have attached two zipped files
one for the musical version of Module 3 volts
one for the musical module Version 1.5 volts
