Introduction: L.E.D Big Dipper
The L.E.D. Big Dipper was designed as an introduction to electric circuits. This circuit includes a resistor, L.E.D. and switch. It demonstrates breaking a circuit and resistance. It provides practice with wiring circuits because there are about 20 connections. This creates an electric, artistic display of the Big Dipper.
Step 1:
Tools and Materials
1. 6 mm foam
2.7 5 mm L.E.D.
3. Telephone wire
4. Duck tape
5. Slide switch
6. Hot glue
7. 9 volt battery
8. 9 volt battery snap
9. Velcro
10. Wirer stripers/ cutters
11. 470 ohm resistor
12.drill
1. 6 mm foam
2.7 5 mm L.E.D.
3. Telephone wire
4. Duck tape
5. Slide switch
6. Hot glue
7. 9 volt battery
9. Velcro
12.drill
Step 2:
Cut the foam to 5 '' by 3 1/2 '' sheets.
Step 3:
Tape the template on the foam and drill 3/64" holes on the dots.
Step 4:
Bend the short LED legs.
Step 5:
Wrap the resistor around the black battery clip wire.
Step 6:
Push the LEDs in to the holes in the foam board.
Step 7:
Wire both legs of the first LED to the second LED and test.
Step 8:
Repeat until the last LED and bend the long legs in the opposite direction.
Step 9:
Wrap the red wire around the seventh long LED leg.
Step 10:
Wrap the resistor around one switch post and another wire around the other then compress each wire bunch.
Step 11:
Cover all the legs with tape.
Step 12:
Put Velcro on the side of the battery shown.
Step 13:
Hot glue the switch to the back.
Step 14:
Attach the battery clip.
