Introduction: LED Brightness Control Using Arduino's Serial Monitor
HIGHLIGHTS:
- Controlling LED's brightness without using potentiometer.
- Allowing float values in map function.
There are variety of applications that was used in this project such as controlling the speed of a motor, proportional valves, and solenoid valves with a more precise speed due to the usage of float values for mapping. Using float values can maximize the use of PWM signal to have more precise control.
Step 1: Circuit
Anode → D3( If you are using different Arduino board, PWM pins might differ. Check the PWM pins for the Arduino board you are going to use )
Cathode → GND
Step 2: Code
NOTE: Download and add the "MapFloat" library before uploading the code. This library will allow you to enter float values for mapping. Download link
#include "MapFloat.h" //Library Source: https://github.com/radishlogic/MapFloat
float PWMVal = 0;
const int pinOut = 3; // PWM Pin of Arduino Nano
void setup() {
Serial.begin(9600);
void loop() {
while (Serial.available()>0){
String myString = Serial.readString(); // Read as String
float myFloat = myString.toFloat(); // Convert it to float
float PWMVal = mapFloat (myFloat, 0,10.0,0,255); // 0->0 , 10->255
analogWrite(pinOut, PWMVal); // Output
Serial.print("LEVEL = ");
Serial.println(myFloat);
Serial.print ("PMW VALUE = ");
Serial.println (PWMVal);
Serial.println("----------------------------");
