Introduction: LED CLOCK in Fusion 360
Good luck!
Step 1: Sketch and Dimensions
Clock dimensions:
- length 200 mm
- height 80 mm
- width 32 mm + edge which is 1 mm but may vary.
-wall thickness of 2 mm, but for the front holes that will allow the passage of light 0.8 mm.
- tolerance 0.2 mm
- the surface on the lid that will help it stay fixed 1 mm.
Box dimensions:
- width 52 mm
- height 60 mm
- length 60 mm
- rear wall thickness 4 mm (because the hanging hole on a 2 mm support will be included)
- tolerance 0.2 mm
- thickness that will serve to include the cover in the clock 1 mm.
Step 2: Work in Fusion 360
Working in Fusion 360, we most often worked with Extrude from the Create bar, from the Modify compartment with Fillet, Spliit Face, Combine, Move and Appearance. The Insect compartment for the Section Alalysis function was also used to work more easily with the interior components. Mirror, Rectangular Pattern and Sketch Dimension were used very often.
Link to download Fusion 360
Link to video inspiration
Step 3: Render and Animation
Rander images are also made in Fusion 360 following the following steps: Design-Render. It is allowed to position the object according to the desire and choose the dimensions of the picture. For the video: Design-Animation. Here also appears the opportunity to disassemble the object and to reassemble.
