Introduction: LED Candle Holder
Welcome to my DIY guide on creating a modern, stylish candleholder that blends art with functionality. Using high-quality stainless steel straws, trays, resin, and LED flickering candles, I’ve crafted a unique piece that brings a contemporary twist to traditional candlelight. This project is perfect for anyone looking to add a touch of modern elegance to their home decor.
Stainless steel straws
Stainless steel rings
Stainless steel trays
Epoxy resin kit
Step 1: Design & Preparation:
Start by designing your candleholder layout. Drill holes in the tray. Arrange the stainless steel straws on the tray.
Step 2: Making Connectors:
I designed a custom PCB, used ferrules.
Step 3: Pouring Resin#1
A resin mold can make it easier. Place the magnets into the holes. Mind the polarity of magnets. The 2 magnets must be in opposite direction. Put the soldered pcbs into the mold and pour the resin.
Step 4: Spring Pins:
Put the pins into the tubes. Use a 0.6mm sheet for spacing. Solder them carefully, do not overheat.
Step 5: Straws, Rings and Resin:
Secure the straws in place using superglue, then mix and pour the resin over the pcbs and magnets, ensuring they’re evenly coated and firmly attached.
Step 6: Candles:
Cut a conduit into 5 cm pieces. The LED needs a current limiting resistor ( 100-330 ohm).
Step 7: Electrical Connection:
Pay attention to the polarity of the magnets and LEDs. I also used a 30-minute timer. Powered by USB 5V or 3pcs AA or AAA batteries. Last step, pour resin and allow it to cure completely.
Step 8: Enjoy the Result :)
https://www.youtube.com/watch?v=Mjt5HfKgmas
