Introduction: LED Chaser Improve Bag!
This LED Chaser is a project created using Arduino Leonardo based on the project that I find on this website (Instructables), made by Shoeb ALI. I improved this project with a few changes and made this better.
This bag could use for going to a nightclub or other places like for example party, this will be a good
Original work website:
https://www.instructables.com/Arduino-LED-Chaser-W...
Improves:
Not like before, only use a box and a button for changing, I create a bag that works on this LED Chaser, and also we could put some useable things inside and bring it to where ever we want. This change contains decorations and also better looking on all sides.
1. Breadboard *1
2. Button *1
3. LED*9 (Red*3/Green*3/Blue*3)
4. Wires*40
5. 220-ohm resistor *1
6. Arduino board *1
7. Portable Charger *1
Decorrection
1. Bag (I use a paper bag)
2. Tape (Including Normal tape and double-sided tape)
Step 1: Connect the Circuits
1. Connect 9 LEDs with RGB pattern (RGB, RGB,RGB)
2. Add the button and test if the LED lighting pattern still works.
3. After that, add some longer wires for letting it can easier for putting on the side of the bag
Step 2: Upload the Code
Step 3: Decorations & Final
For decoration, stick some double-sided tape on a side of the bag, then stick all 9 LEDs and button on it and cover up a normal tape. Put the whole Arduino board inside the bag then it's finished.
Video⬆️⬆️⬆️⬆️
