Introduction: LED Clock
It functions as a very pretty piece of functional art. However, it is missing a home since I do not have space where I live for it :( so it is staying con mis padres at the moment.
It is approximately 30" tall and about 30 lbs? (hard to tell since it is awkward to hold). This makes it difficult to mount to wall (I havn't tried yet). It actually stands on its own surprisingly well by balancing between two of the seconds rods.
Anyways! enjoy this fantastic piece of art and technology!
Here is video. You can see some ghosting and glitching. The ghosting can probably be solved with just using a slightly higher resistor? the glitches are just because some of the wires are loose. I took this video after a few months of this sitting in the cellar and didn't bother to go through the long debugging process of ensuring all proper connections...
Step 1: Materials
Materials:
- 120 tubes 3" long (60 sec + 60 min) = 360" of tubing = 30 feet of 1" steel tubing (this is the hardest part to get just because you need so much)
- 24 tubes 2" long (24 hours) = 48" = 4 ft 3" diameter tubing (I used a broken table support for this)
- 100-200 ft of as thin of wire as you can find (magnet wire is a good option). Also, try to get black wire to blend in better.
144 LEDs
- 60 for the seconds (choose color A)
- 60 for the minutes (choose color B)
- 24 for the hours (choose color C)
- 24 resistors (100 ohms or close)
- Arduino MEGA (you could work to put it onto regular arduino but we need 24 I/O pins in this build)
- DS 1307 (found here)
Step 2: Metalwork
The metalwork, although tedious, is fairly simply (assuming you already know how to weld). I am not going to get into all the how-to-weld topics (there are plenty of other ibles and opportunities to learn this elsewhere)...
Here are the metal-work steps:
Step 1: Cut the tubes.
you need to cut 144 three-inch tubes (1" diameter). I used a horizontal bandsaw with a block clamped down at the 3" mark to cut as quickly as possibly. While this step takes the most time, it isn't that challenging. I would not attempt this without a bandsaw or other power tool as there are a lot of cuts to make...
Step 2: Bend a Circle
To create a guide for when it comes to welding the tubes together, we want to make a circle out of a bent piece of steel rod (1/8" or 1/4" thick) (1" wide). The diameter of this circle is set to be 30" so we need to first cut a length of 30" x Pi = 94.25". Then you need to bend or roll the flat length into the curved circle. This is most easily accomplished in a roller (as I did) or you can take the hard, long, and less precise way of just bending it slowly by hand. It isn't too tough to bend, but it sure wont be as nicely bent as with a roller.
Step 3: Welding
I prefer MIG welding always because it is fast and easy. You can choose whatever welding method / technique you like though. Basically we are just going to make a ton of spot welds. Nothing heavy duty is needed (although you can heavily weld a couple if you want to hang it by them).
With that said, remember your safety!
I found it easiest to start with the minute's tubes. I welded all 60 tubes to the inside of the guide circle bar. Then you can choose to either do the seconds or the hours. I did seconds next, and lastly the hour tubes. For aesthetics, I spot welded (although I think I used an oxy-acetylene torch) a few small rods to the inside. They are completely not needed. The original idea was to mount the arduino to the center but I realized this would look ugly so I stuffed it at the bottom.
(it wouldn't be a bad idea to clean the metal off and de-burr it)
Step 3: Circuit
The circuit is based off of charlieplexing. The circuit is best shown in the pictures... which are basically my drawings on a white-board. Each set of time (hours, minutes, seconds) have their own set of pins (no crossover). 6 pins for the hours, 9 for the minutes, and 9 for the seconds. 24 total.
The third picture basically is just me calculating how much space (as in the angle) each 1" tube takes up and thus what radius circle do I need to hold all the tubes. I also accounted for a little bit of spacing as well. This is how I came up with the 30" diameter.
The hour circuit is shown in the second picture. As you can see, the LEDs marked 1-24 are in use and the additional 6 LEDs (25-30) are not in use (there isn't physically anything in their position). The 6 pins shown on the right of picture 2 are the 6 pins needed from the arduino. These 6 pins control all 24 LEDs for the hour hand.
The chart at the top (in green) on the first picture shows the number of pins needed to control X LEDs using simple charlieplexing. As you can see, n pins can control (n2 - n) LEDs. So to control 24 LEDs we need 6 pins (as claimed earlier) and to control 60 LEDs we need 9 pins.
ignore some of the unnecessary info in green... and ignore the purple and blue... basically, we need 24 pins from the arduino (or whatever). This means we can't use an UNO or Due, rather, we need to use the larger Arduino MEGA which comes with 54 pins. It is a shame to waste all those extra pins, but so be it. You could also use an atmega or anything else, the code is fairly simple.
You will also need a DS1307 Real-time clock (as shown at adafruit) if you want the clock to remember the time after turning it off each time. Otherwise you have to manually set the time every time you start it running. This would mean going into the code each time.
The same circuit can be extended from to 6-pin version to the 9-pin version. The hard part comes with the physical wiring... I would recommend starting with the hour's wiring to get the rhythm before continuing to the more complicated rings.
Step 4: Wiring I
This is the step most prone to errors just because it gets to be a lot of loose wires. Although there is a very clear pattern once you see it. The pattern becomes even more obvious with the 9-pin circles than with the 6-pin hour wiring. However, the 6 pin is more spaced out and is a better place to start to get the hang of the patterns.
I can point you in the right direction and I am glad to offer any advice and answer any questions posted in the comments. However, I firmly believe the best way to do this (resulting in the least errors) is to just try wiring it and that way see the patterns that dictate where each wire goes. This will end up being a lot more helpful than an instruction manual.
The pictures below may come in handy though, at least when starting out. The pictures on this page correspond to how to create each bank of LEDs for the minutes and seconds hands. I started with each LED by bending the shorter lead (-) into a sort of bracket and then ran a slightly curved piece of stiff metal (conductive) wire to connect all of these electrodes. The + leads (longer leads) of the LED were left pointing straight up (down in the picture).
Step 5: Wiring II
more pictures on the wiring process...
these pictures show the hour wiring. It is confusing, I know. Post questions if you have them.
My best advise is to just wire it up and figure out which one is LED 1, 2, .... , 24 in the programming... it isn't too hard to figure out.
Step 6: Wiring III
Finally, the pictures for the minute and second wiring...
I separated the LEDs into chunks of 8 (marked in the picture by the duct tape on every 8th tube). This is needed for the charlieplexing circuit mentioned before. The first chunk of 8 is pin 1, the second is pin 2, etc... The first LED on the first chunk of 8 has a common chunk on pin 1 and a selecting wire leading to pin 2. The next one is also on chunk 1, but has selector pin 3... And once we get to chunk 2 (LED number 9 total), the first LED of this chunk has its selector pin equal to pin 1. THE NEXT LED HAS SELECTOR PIN 3, not 2, because we skip 2 since it is in chunk 2.... this continues on this way all the way around the circle.
The part to keep in mind is that every chunk skips over the selector number that is equal to the chunk number.
This can be very confusing as you get tired and prone to mistakes... it is a very long process. Solder along the way but be prepared to make corrections when debugging...
Step 7: Code
A quick explanation of which pins go where... arduino pins 22-27 are the 6 pins for the hours, arduino pins 28-36 are the 9 for minutes, and 37-45 are the 9 for seconds.
The int arrays a[30] and b[30] together are the 2 dimensional array for the cathode and anode of each LED.
The int arrays c[72] and d[72] together are the arrays for minutes (and seconds since they use the same array). As you can see both arrays are shifted to align the time = 0 position to be at the top of the clock since I didn't put the first LEDs in the right spot when putting it together. You can keep shifting values left or right (just make sure to always to the same to both arrays c & d) until the minute / second hand at time = 0 is at the top.
You do not need to manually set the time since the RTC library does that upon initialization when you load up the sketch.
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
// 6 (hour) + 9 (min) + 9 (sec) = 26 pins needed using charlieplexing to control 144 LEDs on 3 seperate rings.
// 6 pins = used for hours
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
int a[30] = {22,23,24,25,26,27,22,23,24,25,26,27,22,23,24,25,26,27,22,23,24,25,26,27,22,23,24,25,26,27};
int b[30] = {27,27,27,27,27,26,26,26,26,26,25,25,25,25,25,24,24,24,24,24,23,23,23,23,23,22,22,22,22,22};
//can use up to 30 pins. so there are 6 extra positions open for use.
// 9 pins (x2) = used for both minutes and seconds(+9)
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
int c[72] = {32,31,30,29,28,36,35,34,33,32,31,30,29,28,36,35,34,33,32,31,30,29,28,36,35,34,33,32,31,30,29,28,33,32,31,30,29,28,36,35,34,33,32,31,30,29,28,36,35,34,33,32,31,30,29,28,36,35,34,33};
int d[72] = {33,33,33,33,33,33,33,33,34,34,34,34,34,34,34,34,35,35,35,35,35,35,35,35,36,36,36,36,36,36,36,36,29,29,29,29,30,30,30,30,30,30,30,30,31,31,31,31,31,31,31,31,32,32,32,32,32,32,32,32};
// can control up to 72 pins. so there are 12 extra positions open for use.
void setup()
Serial.begin(57600);
Wire.begin();
RTC.begin();
//giving the DS1307 board power (for Arduino MEGA)
//the other bins are wired to SCL and SDA lines on the arduino (for the MEGA they are pins 20 and 21) (for the Duemilanove they are on the analog pins, check the arduino website to read more).
pinMode(18, OUTPUT);
digitalWrite(18, LOW);
pinMode(19, OUTPUT);
digitalWrite(19, HIGH);
void loop()
DateTime now = RTC.now();
//hour
int timeHr = now.hour();
int modHr = timeHr % 24; // modulo 24
//resets each pin so that the pin is neither HIGH nor LOW (so LEDs dont stay on)
pinMode(22, INPUT);
pinMode(23, INPUT);
pinMode(24, INPUT);
pinMode(25, INPUT);
pinMode(26, INPUT);
pinMode(27, INPUT);
//the next several lines grab the position of the LED from the arrays a[] and b[] (cathode and anode) and set them to HIGH and LOW outputs for this loop.
pinMode(a[modHr], OUTPUT);
pinMode(b[modHr], OUTPUT);
digitalWrite(a[modHr],HIGH);
digitalWrite(b[modHr],LOW);
//minute
int timeMin = now.minute();
int modMin = timeMin % 60;
pinMode(28, INPUT);
pinMode(29, INPUT);
pinMode(30, INPUT);
pinMode(31, INPUT);
pinMode(32, INPUT);
pinMode(33, INPUT);
pinMode(34, INPUT);
pinMode(35, INPUT);
pinMode(36, INPUT);
pinMode(c[modMin], OUTPUT);
pinMode(d[modMin], OUTPUT);
digitalWrite(c[modMin],HIGH);
digitalWrite(d[modMin],LOW);
//second
int timeSec = now.second();
int modSec = timeSec % 60;
pinMode(37, INPUT);
pinMode(38, INPUT);
pinMode(39, INPUT);
pinMode(40, INPUT);
pinMode(41, INPUT);
pinMode(42, INPUT);
pinMode(43, INPUT);
pinMode(44, INPUT);
pinMode(45, INPUT);
pinMode((c[modSec] + 9), OUTPUT);
pinMode((d[modSec] + 9), OUTPUT);
digitalWrite((c[modSec] + 9),HIGH);
digitalWrite((d[modSec] + 9),LOW);
pinMode(37, OUTPUT);
pinMode(38, OUTPUT);
pinMode(39, OUTPUT);
pinMode(40, OUTPUT);
pinMode(41, OUTPUT);
pinMode(42, OUTPUT);
pinMode(43, OUTPUT);
pinMode(44, OUTPUT);
pinMode(45, OUTPUT);
digitalWrite(37,LOW); //1
digitalWrite(38,LOW); //2
digitalWrite(39,LOW); //3
digitalWrite(40,LOW); //4
digitalWrite(41,LOW); //5
digitalWrite(42,LOW);
digitalWrite(43,LOW);
digitalWrite(44,LOW); //8@5 off
digitalWrite(45,HIGH);*/
Step 8: Plug and Play
All you need to do is attach leads off of each chunk or selector pin (1 for each of the 24 pins used) and insert it into the appropriate arduino pin slot. Then you need to plug in a power source (9V is easiest, but a range is accepted for the arduino) and enjoy. The clock should wait a couple seconds and then display the time and you can watch it flash away :)
I also attached a switch so that you could permanently keep it plugged in and just use the switch if you ever wanted to turn it off. (shown in the last picture on this step).
It is very visible at night and surprisingly visible in daylight (less so the green hour LED). I also frequently hear complaints about how you can't read the absolute time due to not having numbers, to which I will respond right now with why do you need to know the time down to the second? or within a couple minutes? If you are that obsessed with knowing precise time, you are probably well-trained by now to not trust a wall clock anyways! I have no trouble glancing at this clock and reading the time to the nearest 5 minutes easily. So I say it is very practical. Just don't let the 24-hour time confuse you :)
One last remark: I cannot stop thinking about gatling guns when I look at this...
Step 9: Supplemental Images
Connect every line of the same color (there are 9 pins corresponding to each of the 9 colors used). The diagram is drawn for the minutes section in particular (pins 28-36 for my code).
Make It Glow
18 Comments
5 years ago
Hey Fella, that is epic. Those tacks and pipe cuts would have taken quite an effort. Good on you for sharing with us. Dennis..
Reply 5 years ago
Thanks! Its easy to forget about how repetitive some of those tacks and cuts can be. I definitely got a little sloppy on a few and learned the hard way for what it takes to correct sloppy tacks or cuts. Fun project though!
6 years ago
I like your project very much. I want to copy your project. :) But there will be no pipes. I added a photo. I made that watch. I want to make a new watch. Led will light the layers. There will be 3 layers in the watch, like a ladder. The circle for the hour, the small hoop layer for minutes, the large hoop layer for seconds. There will be no mechanical parts. Thank you very much for your project. (Sorry my English is very bad. I'm using Google translate :-/
Reply 6 years ago
I like the idea, share another pic when you finish?
7 years ago
I've got a question regarding the placement of the resistors. I know they are typically placed on the Cathode side of the LED, but I've also seen it on the Anode side as well. So My question is, does each pin get a resistor between the board and LED chain?
Great build! I am in the process of building a very similar one myself!
Reply 7 years ago
If each pin of the microcontroller has half the resistance needed for the LED, then the current will pass through both resistors (anode side resistor and cathode side resistor) when that LED is on. So yes, each pin going to the MCU gets a resistor. Hope that clarifies!
Reply 7 years ago
make perfect sense thanks!
8 years ago on Step 7
Who says it's bad form to post code?!! It is absolutely appreciated and in some cases crucial to projects explained!! Awesome! awesome project and execution!
and THANKS for posting code!!
9 years ago
I realise that what I need is an image of the 9 pin wiring. Anyone able to help?
I added a picture to an added last step that hopefully explains the wiring better for the 9-pin part. Connect every line of the same color (there are 9 pins corresponding to each of the 9 colors used). The diagram is drawn for the minutes section in particular (pins 28-36 for my code).
Dear LostRite,
Would you be able to draw a few extra diagrams to indicate the wiring. I would like to build this project but am a little confused.
Steve
hi, is the wiring for the seconds and the minutes same as the wiring for the hours?but with extra led-8 in a row?
It is very similar, practically the same. You can look at the code if that helps illustrate that they all use the same scheme. The minutes / seconds ring (they are essentially the same) are just an expanded version of the hours circuit using 9 pins instead of 6. I would suggest looking at the first and second images in step 3. In the second image, you could re-draw it for a 9-pin system by using 8 columns by 9 rows. The 8 columns correspond to the strips of 8 LEDs that I made. The 9 rows correspond to the potential for 9 sets of 8 LEDs. However, since we only need 60 LEDs, we only need 8 of those sets instead of 9 (9 would give 72 LEDs). The wiring is similar to the hours in that it uses charlieplexing, but in many ways it is more organized by using the groups of 8 LEDs. The hours wiring was a bit more scrambled because there was no need to keep it as organized. I hope this helps answer the question. If I misunderstood the question or you have more, please ask.
I am currently home over the holiday break which means I am at home with the clock. So if you want me to take pictures of any of the parts, just let me know!
10 years ago on Introduction
you could use the new arduino leonardo, same size as the UNO, but has more IO pins. 18 digital (extras are in ICSP header and the rx LED, and maybe more), and 12 analog inputs, 6 are in the IO pins so you wouldn't use those, but the other 6 are in the regular analog pins female header. 18 IO pins + 6 analog pins (can be used as IO pins) = 24 total usable pins! just enough for this project.
here is an instructable on the arduino leonardo:
https://www.instructables.com/id/Step-by-Step-Guide-to-the-Arduino-Leonardo/
I might make this, but smaller, and with only 12 hours + LED to show AM/PM, probably a red-green bicolor LED(have some from old electronics). I have a leonardo (I was lucky and got one of the first released ones at makerfaire Bay Area), but will probably use a homebuilt arduino UNO clone or similar. nice project!
If I was to redo it, the arduino would go altogether and I would just use an atmega. Maybe one day when I want that arduino back I will make the swap... as for the bi-color red/green LED, thats brilliant. I debated the 12/24 hr time for some time and only chose 24-hr time for size reasons. Good luck! and post pictures!
Fantastic clock.....love it! You've got my vote!
fun clock. lots of stuff to put together there. I like it
