Introduction: LED Fidget Spinner - How to Increase Spinning Time?
Hi all,
In this instructables I will show you How to increase the Spinning Time of LED Fidget Spinners.
Most of the Fidget Spinner Don't spin for a long time due lack of Weight on the edges.
Step 1: Things You Will Need?
Led Fidget Spinner X1
Normal Fidget Spinner X1
Super Glue, Fewikwik OR Araldite ( Clear Adhesive)
Step 2: Remove Leds
Remove the Led modules from the led Fidget spinner & keep it aside & Carefully remove the Leds from the White led Caps Check the images for reference.Remove the center bearings as well and keep it aside you don't want the glue to go inside your bearings.
Step 3: Stick the Front Caps of the Led
Use the glue & stick the front facing of the caps as I have done.Please check the Images for reference
Step 4: Place the Leds
No once you kept it to dry after that Place the Led back in to the white caps
Step 5: Ready to Spinnnn
You will notice that it will spin for longer duration
If you want me to make a Acrylic cut for the same please comment below.
Thank you.
https://youtu.be/psQatKcSlps
Step 6: Check This Video
Thank you.
