LED Frosties
Intro: LED Frosties
Light up your cooler with some waterproofed LED lights. They're simple to make and easy to reuse.
STEP 1: Light It Up
All you need is a couple dozen 10mm diffused LEDs and some CR2032 batteries. Clip the leads a little and slide the battery up between them. If it didn't light up, flip it the other way.
Now tape it up and repeat until you have a small pile of glowing lights.
STEP 2: Start the Wrap
Tear off a square of plastic wrap and push the LED light up into the middle of it.
Now pull the rest of the plastic wrap back so it looks like a plastic comet.
STEP 3: Tie It Up
Twist the tail a little tighter and knot it up. You can trim the excess off or leave it.
If you have some small Ziploc-style bags you can use one or two of those instead. You could also try doubling back the plastic wrap and make it more secure. I just had a bunch of LEDs, batteries, and drinks lying around so I put this together and it worked for the few hours I needed it.
STEP 4: Toss Them Into the Ice and Stir
Spread the lights around the ice in the cooler and stir it up a bit so some of them get under the ice to create the glowing effect.
STEP 5: Add Drinks and Enjoy
Do you need a description here? Get some drinks and enjoy!
Break the plastic wrap when you're done to save the LEDs and batteries for later.
See also:
- LED Throwies
- The Ice Bulb
- LED Floaties 1
- LED Floaties 2
See also:
- LED Throwies
- The Ice Bulb
- LED Floaties 1
- LED Floaties 2
59 Comments
jnixon 16 years ago
Bot1398 12 years ago
AngelInTheNight 12 years ago
doo da do 16 years ago
Koil_1 15 years ago
crak-a-bottle 14 years ago
waterproof throwies =]
inventorjack 15 years ago
fungus amungus 15 years ago
nrlucre 16 years ago
I bet you could do this via klee27x's "Pocket Full Of Anything""Pocket Full Of Anything" technique to make a tidier container for your LED.
sjrSpike 15 years ago
Depending on the amount of air, could you get these to float at different levels in the pool?
fungus amungus 16 years ago
imarzouka 16 years ago
Iyad Marzouka
http://ledcalculator.net
geeklord 15 years ago
The_Beast 15 years ago
godmode 15 years ago
lukeair45 15 years ago
stanstan009 15 years ago
pixelitis 15 years ago
