Introduction: LED Handie
This is an instructable on how to make a LED Handie. I call this a LED Handie because you can hold it in your hand without much effort and it's handy. You can use the Handie for anything that you want...A little decoration, a nifty little toy, something to spook your friends by hiding it in their shoe, stuff like that. This instructable doesn't cost much... You just need a LED pen (certain type...look at next step), paper clip, and some silly putty...
Step 1: What You Need
All you need is:
1. A LED pen--find these at fundraisers, dollar store (i think), and online. Buy LED pen HERE
2. Large paper clip
3. Some silly putty or something sticky like that.
2. Large paper clip
Step 2: Start Taking Apart the Pen
Pull off the front section (the pen part) of the pen. Pull hard it will slide out easily.
Unscrew the back section of the pen (see picture #1).
Now you are left with this... (see picture #2).
Now slowly pull out the black capsule with the LED light in it (see picture #3).
GO ONTO NEXT STEP
GO ONTO NEXT STEP
Step 3: Making the Handie
All you need is the LED part (see picture #1), a paperclip, and some silly putty or something sticky like that.
Assembly--part 1
Get out a large paper clip and cut it like in picture #2.
Once you have cut the paper clip, you want the biggest part of it.
Once you have done that get a piece of silly putty or something like that and stick the biggest cut off piece of paperclip into it (look at picture #3).
Take the silly putty-paper clip thingy and push it into the spring...the cut off part of the paper clip should be able to stay in the spring without you having to hold it up (look at picture #4).
Now push the paper clip a little bit more up the spring and stretch the spring a little bit farther down the paper clip. The LED light will light up and then it will be stuck so that your free to wave around the LED light without having to keep on pressing the paper clip against the battery to keep it lit.
(see pictures #5 & 6)
Assembly--part 1
Step 4: Have Fun!
Now you are done!
Uses for Handie:
Put it in someone's shoe and see the look on their faces when they see that their shoe is glowing blue.
Use it as a mini flashlight.
Stick it on the wall with the silly putty on the end.
Think of more things to do with it... It's handie!
HAVE FUN!
Uses for Handie:
HAVE FUN!
