Introduction: LED Hotwheels
Heres how to turn your favorite hotwheels car into an awesome light-up display or night light.
Step 1:
To take apart the car, you must first turn the car over and drill out the mounting rivets that hold the car together.
Step 2:
Next we use masking tape to cover the car up so you dont scratch it all up.
Step 3:
For this step you prep the car for the holes that will be drilled out for the head and tail lights.
Step 4:
Now drill your holes.
Step 5:
Next we add some leds to the car. I used some five minute epoxy to glue the leds in place.
The circuit is pretty simple series / parallel combination. The parts needed are::
- 2 red leds (tail lights)... i used red 3mm
- 2 white leds (head lights). . .i used some small blue smd that i had
- 1 150 ohm resistor 1/2 watt
- 1 9 volt battery
- some wire
Step 6:
Here you wire it up using this schematic. Then modify the windshield and seats of the car so that the resistor and leds fit when they are assembled.
Step 7:
final assembly and power test. Heres a few others that i did for some friends.. .
