Introduction: LED INTERFACING WITH 8051
LEARNING EMBEDDED C PROGRAMMING FROM SCRATCH
I just started with learning Embedded C programming so , I just decided to blog every single practice projects I code to upload it directly here to make sure i can easily memorized how i did it last time and to keep a track on my progress.
Let's Begin
  1. 8051 Microcontroller
  2. LED
Step 1: Steps and Circuit Connects
  1. first connects Anode of the LED's to the Port P2 pin of 8051 (You can change Output pin port of 8051 as per your desires to any other Port )
  2. Connect Cathode Pin of LED's to the Ground
  3. Connect the 5V power supply to the 8051 and ground it
  4. Check all the connects properly as per the above connects
  5. Now, dump the Hex file generated into 8051
Step 2: C Program
#include<reg52.h>
void Delay(void);      // Function prototype declaration
void main (void) //main
  while(1)        // infinite loop
    P2 = 0x00;      // LED ON
    Delay(); //Function call
    P2 = 0xff;      // LED OFF
    Delay();
void Delay(void)
  int j;
  int i;
  for(i=0;i<10;i++)
    for(j=0;j<10000;j++)
Step 3: Detail Explaination to Program 8051
8051 is microprocessor while programming 8051 we need to include reg.52.h library
Any port of 8051 can be defined by just typing P0,P1,P2,P3
declaring P2 =1 it actually means we are initializing all pins in PORT2 as HIGH
To initialize the port either as LOW or HIGH we just need to declare port as 0 or 1 . eg - P2=0 or P2= 1
To Define any single pin from PORT we just need to say P2^0 where 0 points to pin 0 in port 2
or similarly to define port 2 pin4 we can write as P2^4
Lets me show how we can just use single pin instead of all
PROGRAM TO DEFINE PORT 2 PIN 0
#include <reg52.h>
sbit LED1 = P2^0;
void Delay(void);
void main (void)
    LED1 = 0;      // LED ON
    Delay();
    LED1 = 1;      // LED OFF
    Delay();
void Delay(void)
  int j;
  int i;
  for(i=0;i<10;i++)
