Introduction: LED Light - Up Shirt
My favorite band is Maroon 5 so before I attended a recent concert I decided to try my hand at making a light up shirt that would "attract" the band's attention! I used sew-able LED lights. Of course my shirt color was maroon!
Step 1: Items Needed
Here is a list of the items that I used to create my shirt. I purchased them from the site, www.sparkfun.com
LilyPad Arduino 328 Main Board
LilyPad LEDs White
Conductive Thread Bobbin - 30ft (Stainless Steel)
LilyPad FTDI Basic Breakout - 5V
SparkFun USB Mini-B Cable - 6 Foot
Craft Puffy Paint
Step 2: Placing LEDs
I "grouped" about 8 LEDS and used the conductive thread to stitch them. As you can see in the picture I had five sections. I sewed all of the negatives on the LEDs using one line of conductive thread.
Step 3:
You can see the running stitches from the LEDs down to the Main Board. I used ports A1, A3, 13, 9, 7, and 12
I used the Arduino software to program the 328 Main Board so that each port would turn off/then on creating a blinking pattern. Below is the code I used:
int led = A1;
int led1 = A3;
int led2 = 13;
int led3 = 9;
int led4 = 7;
int led5 = 12;
// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin 13 as an output.
pinMode(led, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led1, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led2, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led3, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led4, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led5, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000);
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
digitalWrite(led1, LOW); // turn the LED off by making the voltage LOW
digitalWrite(led2, LOW); // turn the LED off by making the voltage LOW
digitalWrite(led3, LOW); // turn the LED off by making the voltage LOW
digitalWrite(led4, LOW); // turn the LED off by making the voltage LOW
digitalWrite(led5, LOW); // turn the LED off by making the voltage LOW
delay(1000);
Step 4:
After I tested out my shirt to make sure it worked correctly, I purchased Puffy Paint from a craft store and covered my conductive thread with it. It helps to keep it in place and protect it.
Step 5:
In this picture you see the FTDI board attached to the 328 Main Board. Then I attached the USB cord to the FTDI board through a slit I made in the shirt and the USB attached to the Energizer battery. I just kept the battery and cord in my jean pocket.
I am sad to say that no band member acknowledged my flashing shirt -- but it sure got me the attention of those around me!!!
