Introduction: LED Pain Reliever
An internet search for "near infrared light therapy" will provide you with more facts than you can take in and more fallacy than you can imagine. At this point in time one thing is sure - near infrared light (IR) therapy does relieve pain. The FDA has even approved it for such. However, other snake oil claims such as wrinkle and cellulite removal are not yet proven.
NASA is at the forefront of near IR light therapy research and has many publications dealing with the subject. (links below) One publication deals with the effectiveness of the therapy for pain management in cancer patients undergoing chemotherapy and/or radiation treatments.
http://spinoff.nasa.gov/Spinoff2008/hm_3.html
http://www.nasa.gov/topics/nasalife/features/heals_photos.html
Commercial LED near IR light units are available for a couple of hundred dollars to many thousands.
This unit can be built for less than $50.00 using all new off the shelf parts. I built this for my wife to use for neck and shoulder pain. She uses it every day and says it works great. I used it myself for awhile following carpel tunnel surgery and was amazed at the level of pain relief it offered. It was more effective than the pain medicine the doctor prescribed for me and the relief lasted for several hours after use.
Note that the purple color in the picture is only visible when photographing the operating unit with a digital camera. With your eyes you only see a small bit of red glow inside the LEDs.
Biochemtronics
Step 1: The Parts
- The 850 nm infared LED circuit board with LEDs and resistors
- A 12 to 15 volt wall wart
- A micro sized fan to cool the unit.
- Some sort of screen to keep your fingers out of the fan during use.
- A small switch - this is optional as you can always just plug and unplug the wall wart
- Sugru to hold it all together (Epoxy putty or silicone might also work but won't be as easy to work with as Sugru)
Sources for the main components are shown below:
LED UNIT - This kit contains 36 - 850nm 20 degree IR LEDs. $25.70
https://www.bgmicro.com/search.aspx?find=led1092
Wall Wart 12-15V 160mA. $5.10
https://www.bgmicro.com/PWR1170.aspx
12 vdc Micro Fan $15.49
http://www.radioshack.com/product/index.jsp?productId=2102824
Sugru - costs a few dollars per pack.
http://sugru.com
Step 2: The Build
Step 3: Use It
The IR from this unit penetrates the tissue for a little more than an inch. You can verify this by shining it through your hand in a darkened room and viewing the IR light coming through the other side of your hand with a digital camera.
The unit will get warm to the touch even with the cooling fan. This is normal. Like everything that uses electricity, this thing produces some heat. Be careful not to block the air flow to the fan with your fingers during use. If you do you will hear the fan speed up and the unit will start to get uncomfortably hot.
This is near infrared light, not infrared, so long exposures are not going to harm you regardless of what the folks in the want-to-be medical expert peanut gallery may say in the comments section.
Enjoy the build.
Randy
