Introduction: LED Table Lamp From Steel Straw and Deo Caps
I have created this LED table lamp using old Stainless Steel Straws, 1 Watt LED with heat sink, Deodorant can caps, Old hard disk stainless steel top cover, two core Wire, Micro USB female connector.
- Stainless Steel Straws - 2 Nos.
- Deodorant caps with stainless steel finish - 2 Nos
- 1 Watt LED with heat sink - 2 Nos
- Coins - 2 Nos
- Old hard disk stainless steel top cover - 1 No
- Wire
- Micro USB female connector - 1 No
Step 1: Make Holes in Straw
Make one through holes in two straws and connect them together using screw and nut
Step 2: Prepare LED
Solder two 10 cm wires to each LED and glue them on coins so that the coin will work as additional heat spreader
Step 3: Cup Holder Clip
Take a 5cm stainless steel strip and make a loop on one end such that it will snap fit on straw
Step 4: Glue Both the Cups and Clip
Glue both the cups and clip using epoxy or instant adhesive.
Also make two holes on the base of cups and thread the wires of LED through them. Glue the coins holding the LEDs to the base of cups from inside.
Step 5: Prepare Main Straw Attachment
Take some plastic pieces with a hole sized same as width of a straw and glue them together using instant glue.
When dried, fix the plastic base on hard disk top using epoxy or instant glue
Step 6: Attach Wire and USB Connector
Glue the female micro USB connector from inside the hard disk cover using epoxy glue.
Solder two wires, +ve and -ve, to USB connector and thread it through the straw up to cups and solder the two LED wires.
Fix the main straw into the plastic base on hard disk cover.
Step 7: Final Step
The LED lamp is ready for use. Attach a standard USB charger and it goes...
Enjoy it while reading or use as night lamp.
