Introduction: LED Bedside Lamp
A short time ago a friend asked me about the 50 watt solar panel they sell at H.F. That's not much power and running it through an inverter would just be silly. So I started trying to come up with something useful enough to justify the purchase.
I found an LED that puts out 420 lumins and only uses 5 watts. (this LED is only 20 bucks)
This is just enough light for a nice bedside lamp , and at only 5watts you could run ten of them off a 50 watt solar panel.
That's about as much light as a 40 watt light bulb . If you had ten 40 watt bulbs in your house and you replaced them with these you'd save 350 watts (that's a lot of watts).
If you'd like to build a few just follow this instructable. And remember , stay safe , have fun , and every dollar you save doing something green is a dollar that can be put back into the economy some where else to help make it strong again.
Go Green for the Green !!!
Step 1: Stuff You'll Need
Your going to need a nice little lamp and a socket that will except this LED (pm me for link)
Step 2: Test Your LED
I set up two 6 volt batteries to get 12 volts to test my lamp.
When this item is finished I will ether use a doorbell transformer or a cellphone charger so I can plug her right into the wall.
Step 3:
Now that you know she works just wire her up .
Step 4:
Now just set it next to you bed and enjoy.
You now own the coolest , most green light on your block.
Send me a pm if you have any questions and friend me on facebook. I'm always doing something fun and green.
