Introduction: LED Candle From Lasercut Parts
This instructable is for my lasercut LED candle design that you can download from Thingiverse. It's a simple but useful electrical circuit that you make out of wood and copper tape (or cardboard and aluminum foil - I'll explain later about alternative materials). We make this at Ace Monster Toys in Oakland, CA for our Hacker Scouts program, where kids 7-14 put it together themselves. Young kids may need some help from their parents. A little manual dexterity is required to get the parts to line up.
Because this is an educational project it's intended to be inexpensive at scale. There are only two electrical components (the LED and the battery) and if you buy them in bulk, and use the full roll of copper tape, it should come out to less than $1 per candle.
This first version of the candle doesn't flicker; it's really more like a little flashlight, but it's a nice shape and size to be used in lanterns or halloween pumpkins. I'm working on a design that uses a programmable ATTINY85 chip to flicker the LED.
Submitted by Ace Monster Toys Hackerspace in Oakland, CA for the Instructables Sponsorship Program
Step 1: Materials List and Tools. Also: What to Use If You Don't Have a Lasercutter
If you've used the Thingiverse design to cut your pieces out of wood, you should have the parts shown here: Candle pieces 1, 2, and 3, plus a base and a switch arm.
Additional materials:
1 LED. I like the jumbo 10mm LEDS, for example this yellow one from Jameco.com
1 CR2032 battery, available from adafruit.com and at most DIY hardware stores
1/4" adhesive copper tape, you can find it on amazon (see below for alternatives)
A bamboo skewer or short 1/8" wooden dowel
Tools:
Scissors
Wood glue
A strong clamp (an office binder clamp works well)
Wire cutters
What if you don't have a laser cutter?
You can cut these pieces out of 1/8" corrugated cardboard using a craft knife, or out of 1/8" wood using a scroll saw. You can even cut them out in layers of thin cardboard with scissors, and glue the layers together. if you choose a different material just pay close attention to the thickness of piece #2: It should be almost the same thickness as the battery. All of the parts need to be strong enough to hold up to use, and they need to be non-conductive, but if you keep those things in mind you can cut them out of anything you like.
Alternatives to copper tape
Since I was making a lot of these at Ace Monster Toys I bought a whole roll of 1/4" adhesive copper tape, but that's expensive. One alternative is to buy a smaller roll of copper tape from your local garden center - they sell it there as a snail deterrent. You'll need to cut it down into 1/4" strips. The simplest alternative of all is to use ordinary aluminum foil from your kitchen. Again, you'll need to cut it into strips, and you'll need to glue it. Rubber cement will work better for this than wood glue. Aluminum foil is thinner and more delicate than copper foil, so the key thing is not to leave any jagged edges that could tear as you move the switch arm.
Tools:
Scissors
Wood glue
Wire cutters
Step 2: Apply the Copper Tape
Turn part 1 over and apply the copper tape to parts 1 and 3, and to the switch arm, as shown here. The two pieces of copper tape on piece 3 do not touch! This is important. When the candle is assembled the switch arm will connect these two strips and complete the electrical circuit.
Use your fingernail (or a friends fingernail, or something else that won't tear the metal foil) and push the metal foil gently into the slit at the top of piece #3. You can see this in the picture if you look closely. The idea is to make enough room for the 'leg' of the LED to fit into the slit and be in contact with the metal.
Step 3:
Now check the fit of the battery by sliding it sideways into piece #2. It should slide easily into the circle. If it doesn't fit, use a craft knife to remove a little bit of the upper corner of wood until the fit is right.
Step 4: Clamp the Pieces and the LED Together Without Glue
Your LED has two legs, a long one (the + leg) and a short one. In most LEDs these start out about 1" long, so you'll probably want to use the wirecutters to trim the legs so the LED sits just above the candle - but make sure when you trim them the + leg is still a little longer so you can tell which one it is!
Slide your LED over part #2 with one leg on either side. The long leg, the + leg, should face up - towards piece #1 and the + side of the battery.
Stack the pieces face up with #3 on the bottom, #2, then #1. Clamp them together as shown here.
Before we go on to the next step, take a good look at your candle, particularly around the legs of the LED. The wood pieces should fit tightly against each other and the LED legs should be pressed into the slots at the top of pieces 2 and 3. If the legs of the LED are creating a gap between the wood pieces then the electrical contacts won't be good and the candle may not work. When I'm debugging (trying to fix) people's candles this is almost always where the problem is - so look at it carefully now and tweak it if needed.
Step 5: Insert the Battery and Switch Arm, and Test
Slide the battery and the switch arm into place - still without gluing. The LED should light up when the switch arm is closed. If it doesn't, press the candle together around the battery and the switch arm. Add another clamp underneath the battery and see if that helps. If you absolutely can't get the LED to light, take a look at the debugging step and try to figure out what's wrong. Don't move on to the next step - gluing - if it doesn't work.
Step 6: Glue, Clamp, Let It Dry
When you're confident that everything works, take the parts apart so you can apply the glue. Glue pieces 1, 2, and 3 together with the LED, and clamp them while they dry. The clamp is very important - the layers need to be tight together to let the electrical contacts work. Put one clamp at the top around the legs of the LED, and a second clamp below the battery compartment.
Let the glue dry for at least an hour (or follow the instructions on your glue).
Step 7: Finishing Steps
When the glue is dry, remove the clamps.
Put the battery in. Slide the switch arm into place and put the skewer or dowel through the hole. If it's too tight, sand it down until it fits snugly. Make sure the switch arm can move freely. Trim the dowel with the wire cutters.
If the dowel isn't tight enough to stay in place with friction, glue it to the outsides of the candle - but don't glue the dowel to the switch arm, you want that to stay moveable.
