Introduction: Lego NXT MLRS
This is a lego NXT MLRS missile launcher which shoots rubberbands. Created & designed by Muchen.
Step 1: Materials
You will need:
LEGO NXT MINDSTORMS 2.0 KIT
Computer
An android/ apple mobile phone/tablet/ipod
Step 2: Attach Tracks to the Motors
Copy what I did in the photos, be sure to use the pinhead grey stick. Then just attach to the bottom of motor. On the other side of motor attach 2 black mini tubes. Then just make another one! Of course this time the wheels go on the other side of the motor.
Step 3: Joining the Motors Together
Now make the 2 types of connectors to join the motors together:D
Step 4: The Base & Cabin Holder
Build this, this goes in between the motors and this will hold the base and the cabin.
Step 5: The Base
Make the base all u need is some tubes and beams. Then fix this onto the 'base & cabin holder'.
Step 6: Make the Rotatory Base
This base will allow you to move your missile turret up and down, left and right. Once built attach to back of base
Step 7: Building the Missile Turret
First of all build 2x structures 1 and 2 (tagged in photos) . link them together with a long black connector. Then build the firing motor which is a motor with tow mini gears each side. Then connect the motor to the 2x structure 1 and 2. Finally attach it to the rotatory base.
Step 8: Building the Roof of the MLRS
Build this structure, remember to leave a slight gap for the top of the motor to fit. Then use the bent beams to attach to the firing turret.
Step 9: Attach the "cabin"
The cabin is actually very simple to attach, because it is the NXT brick! Basically attach the nxt brick to the base & cabin holder. *refer to step 4 if needed.
Step 10: The Wiring
Attach all wires to ports A, B, and C side of the NXT brick, since there is no sensors built in the MLRS. Note that The 2 driving motors goes to port B and C and firing motor goes to port A.
Step 11: Remote Control
Please download apps such as Mindroid app for android devices or iNXT remote for iOS devices https://play.google.com/store/apps/details?id=com.urbandroid.mind&hl=en
https://itunes.apple.com/gb/app/inxt-remote/id317399938?mt=8
If you have a bluetooth enabled computer you can use the default remote app included in your NXT Mindstorms software CD.
Then test your MLRS out! If your MLRS did not go in the direction you wanted it to go please rewire your motors to a different port, but keep firing motor at port A. Thanks for reading this instructables.
