Introduction: LEGO Raspberry Pi Zero Case
About: Curios siblings duo learning and making adventures. Parent run feed.
We were looking for an easy way to integrate a Raspberry Pi Zero into LEGO builds. There are some LED brick choices on the market but none worked for us either due to limitations in use, power or features. The Pi offers all of these in a small format including WiFi & Bluetooth!
Step 1: Cut the Bricks
Using a rotary tool, we cut small incisions in the side of the white bricks. Just enough to hold the Pi Zero W in place.
Step 2: Remove Pins Where Needed to Allow Cables Access
Make sure to cut with blade facing away from you to avoid injury.
Step 3: Assemble the Pi and Enjoy!
Once you are satisfied with the case and air circulation between the Pi and the LEGO bricks. You can place the micro controller inside your build and start building around it as needed.
DON'T FORGET TO LEAVE ROOM FOR AIR CIRCULATION AND COOLING!!!!
Step 4: Materials
Two 6X10 LEGO Plate/Element ID: 4211405 Design ID: 3033
Four 1X1 Brick/Element ID: 4211389 Design ID: 3005
One Raspberry Pi Zero W
Rotary cutting tool
Safety glasses
