Introduction: LEGO Spinning Tops With "how to Play Instructions"
Hi again!
I Want to introduce you our Lego Spinning tops collection and battle game.
They are so easy to build it up, and can be made it up more and more complex only by adding some pieces.
The only one thing to carefully take notice is about build it up ever in a balanced manner. if you place some piece,
you must place an equal one on the other side of the top.
In the different steps, following the picts you can see how I build them.
(Ah, If you like it, do not hesitate to vote it (and also my other lego i'bles) :) )
Hola Otra vez!
Quiero presentaros mi ultima creación. Una colección de peonzas LEGO.
Son muy fáciles de construir todo y que pueden complicarse ad infinitum añadiéndoles piezas y más piezas.
La única cosa que se ha de tener en cuenta es construirlas balanceadas, buscando la estabilidad. Si pones cualquier pieza, en el otro lado(s) de la peonza tendrás que poner otra igual.
En los diferentes pasos, siiguiendo las fotos podrás ver cómo las he construido.
(Ah, y si te gustan, no dudes de votar este proyecto (al igual que mis otros proyectos LEGO) :) )
Step 1: How to Play?
We play with this tops as a battle with two variations:
-Staying alive:
All participants build up a "compact top", thats it: a top without strange pieces, compact like "Fatboy Slim" or "Flying saucer".
Draw a 30cm radius circle on the ground (+or- 12")
At 1,2,3 count, all participants throw her top trying to hit the other ones and send them outside the arena.
Winner is who her top stay more times after 3,5 o 7 sets.
-Beyond Thunderdome
All Participants build up a complex top like "I.S.S", that's it, a top with decorations and "easily" destructible.
One of the participants throw her top in the Thunderdome (while crying: "Two men enter").
The other participant throws her top (while crying "One man leaves") trying to impact and destroy the other participant top.
Winner is who her top is less damaged or resist the impact without stop spinning.
En casa , jugamos a batallas con estas peonzas con dos variantes:
-Staying Alive (mantente en vida)
Los participantes han de construir una peonza compacta, es es: Peonza sin piezas raras, compacta como "Fatboy Slim" o "Flying Saucer".
Se dibuja un circulo de unos 30cm en el suelo.
Y a la cuenta de 1,2,3 los participantes lanzas sus peonzas tratando de empujar a la del rival fuera del campo de batalla.
El ganador es el que gana más veces después e 3, 5 o 7 sets.
-Más allá de la cúpula del trueno.
Tiodos los participantes construyen una peonza compleja, como "I.S.S", o sea, con decoraciones y facilmente destruible.
Uno de los participantes lanza su peonza en "la cúpula del trueno" (al grito de "Dos hombres entran!).
El contrincante lanza la suya intentando impactar con la primera (gritando a su vez "Uno Sale!")
El ganador es el dueño de la peonza que: o resulta menos dañada o que una vez después del impacto sigue rodando.
Step 2: Squarepusher
An easy one to build and also is super stable. And also is a good base to build also compact or complex tops.
Muy fácil de construir y súper estable. Además, es buena para ser la base para construir tanto peonzas compactas como complejas.
Step 3: I.S.S.
A good demonstration of what I call a Complex top. This model is super fast and stable.
Una buena demostración de lo que yo llamo una peonza compleja. Este modelo es muy rápida y super estable.
Step 4: Fat Boy Slim
This compact top spin better as I suppose .
Esta peonza compacta gira mejor de lo esperado.
Step 5: Flying Saucer
This is one of the best compact top. Only four pieces has been used to build it up.
The result is a fast and stable top.
Esta es una de las mejores peonzas compactas, Solo he usado cuatro piezas para construirla.
El resultado es una peonza muy estable y rápida.
Step 6: Little John
Hi speed spinning but with a leak of stability.
And... That's it, Hope you like it, and post photos if you build some!
Alta velocidad pero con cierta perdida de estabilidad.
Y... Ya está! Espero que te gusten y si construyes alguna posta fotos!
