LEGO Minifig Key Chain Removal
Intro: LEGO Minifig Key Chain Removal
I recently went to the LEGO Store to buy a Star Wars C3PO minifig, but he was only available in large kits and I couldn't buy him separately. I was told that they had the astromech in keychain form, but you can't remove the head or the legs. Not to be denied the driod I was looking for, I bought him and decided to try and remove the key chain myself. A little Internet searching revealed that many people have had this exact same problem, here's how I solved it.
Removing the key chain from your LEGO minifig is easy. After, you'll be able to switch out heads or add your favourite hat. All that's left is a small opening where the friction fit pin was; this small opening can be filled in with coloured putty or some other type of filler and painted to match.
brute force method:
cutting method:
soldering iron method:
I hope this helps you transform your keychain minifig into a playable addition to your LEGO set. Remember to show off your completed key chain removal minifigs in the comments below!
Have fun!
brute force method:
- paperclip
- pliers
- cloth
cutting method:
- heavy cutters / rotary tool
- soldering iron
Have fun!
8 Comments
Peltaclass7 8 months ago
hamzazouk 1 year ago
ElijahP2 8 years ago
qirien 9 years ago
Thanks for the instructions! We used the brute force method, but it works much better if you use a hairdryer to heat up the pin and soften the plastic.
freetree123 10 years ago
barista 10 years ago
SHIFT! 10 years ago
Penolopy Bulnick 10 years ago
