Introduction: LEGOs Out of LEGOs
This instructable will show you how to make a lego three times the size of a normal one using:
4 1X2
4 1X4
a 4X4 plate
a 2X2 cylinder
8 1X2 plates and
2 1X4 plates.
You should probably try to use only one color, but i didn't have enough.
You can actually make this instructable with other pieces as long as it's hollow and 3X3X3.
4 1X2
4 1X4
a 4X4 plate
a 2X2 cylinder
8 1X2 plates and
2 1X4 plates.
Step 1: Start Your Building!
Place a 4X1 brick, then two 2X1s. Finish it off with another 4X1.
Step 2: Going Up!
Rotate the bottom 90 degrees and repeat.
Step 3: Now for the Plates...
Rotate yet another 90 degrees and repeat, but this time with plates.
Step 4: Continue...
Rotate another 90 degrees (this is the last time) and add:
two 2X1 plates facing horizontally
two 2X1 plates facing vertically and
two more 2X1 plates facing horizontally
Step 5: Top It All Off
Add the 4X4 plate and top it all off with the 2X2 cylinder.
Hey, you're done!
Hey, you're done!
Step 6: But Wait, There's More!
You can make more sizes and shapes if you like, the possibilities are endless!
