Introduction: LOVE SHACK
About: I am an artist living and teaching ART in NYC for over 30 years, and I am a CZT, Certified Zentangle Teacher. I love to explore all sorts of art making both in my teaching and in my own work...check out my sit…
Love Birds....Love Nest.....Ceramic Birdhouse, easy to make for your Valentine
Step 1: Supplies
Step 2:
Clay
rolling pin
Cutting tool
6"X13" template
6"X7" oval template
underglazes
glaze brushes
thin wire
pencil
glue stick
 *access to a kiln
Step 3:
Roll clay large enough to fit ^'X13" template
Step 4:
cut the clay
Step 5:
Using the hollow end of a glue stick make a hole as close to the center of the clay slab as possible.
Step 6:
Roll the slab into a cylinder shape.
Step 7:
roll another slab of clay slightly larger than the cylinder. Place cylinder on clay and cut around bottom edge leaving about 1/8 inch of excess clay.
Step 8:
Reach inside cylinder and gently press against the bottom edge at the same time push the clay up and against the outside of the bottom edge. Use your fingers on the inside so the pressure doesnt make the cylinder collapse.
Step 9:
Step 10:
Squeeze the top of the cylinder closed making sure the hole is in the front
Step 11:
Roll more clay for the roof
Step 12:
Place the oval template on the slab and cut
Step 13:
Place the clay on top of the cylinder
Step 14:
gently squeeze the clay across the top of the roof
Step 15:
using the pencil poke holes along the roof top These will later be used to hand the love shack.
Step 16:
when dry fire to bisque
Step 17:
use underglazes to paint the decorations on your love shack.
Step 18:
glaze
Step 19:
Be sure the glaze does not clog the holes in roof
Step 20:
fire the birdhouse again and then put the wire into the holes on the roof so you can hang it.
Step 21:
Present your Valentine with a hand made LOVE SHACK
