Introduction: LP-2010 AES17 1998 Switching Amplifier Low Pass(low-pass) Filter
This is a great D class amplifier
measurement of low-pass filter.The fine workingmanship,superiro performance,easy connection make this product easy to use and very worth owning with a high cost performance .
Step 1: Easy to Use
Easy to use
simple connection,it only takes 3 mins from unpacking to using
True differential input,suitbale for the bridge output structure
Single-ended output,the output buffer stage can load multiple connections
Simple power input,the built-in power converter module provides power supply for internal circuity
Step 2: High Cost Performance Where Needs It ?Who Needs It ?
Superior Performance,But Low Price
10% for less than the price of branded products,with most of its performance
Superior frequency response and distortion
Very easy to extend range,brings endless appreciation potential
Abundant high-quality accessories,without additional cost
Where needs it ?
Low-power switching amplifier measurement
Hands-free bluetooth audio parameters debug and test
Mobile audio products parameters debug and test
Multimedia audio products audio parameters debug and test
Low pass filter for digital audio decoder
Who needs it ?
Amplifier products manufacturing plant
Specialized for Maintenance Testing
R & D engineers, to debug switching amplifier
Personal, for DIY digital audio products
Step 3: Technical Parameters
Specifications
Frequency Response ±0.1dB , 10Hz to 20KHz
Insertion Loss 0.05dB , typically
High-frequency(HF) Inhibit > 60dB , 250KHz to 20MHz , typically
Maximum Input (without extension) ±10V peak
Channel Isolation > 90dB @ 20KHz
Distortion < 0.005% harmonic (1V 1KHz)
Dimension
Temperature
Suitable Temperature +5°C to +40°C
Storage Temperature -40°C to +75°C
Humidity 80% RH to at least +90°C
Dimension 105 * 165 * 36 mm
Step 4: Packing List
1 X INHAOS LP-2010 Low Pass Filter
1 X User Manual
1 X DC9V 500mA Power Supply
2 X BNC Tee Connect
1 X BNC to BNC Audio Cable
1 X RCA to BNC Audio Cable
2 X Speaker Cable
https://www.ebay.com/itm/320684011405
