Introduction: Lab 1 - Serial Demo
This example demonstrates how to use Serial input to control LEDs
Step 1: Adding an LED
1. Place an LED (any color) into the breadboard
2. Connect one end of 220 Ω (ohm) resistor to the top lead (+), should be the longer lead, and the other end into Pin 3 on your Arduino Board.
3. Connect a Jumper Wire to the bottom lead (-) and to the grounded rail on the breadboard.
4. Connect a Jumper Wire from the grounded rail to the GND (ground) Pin on the Arduino.
Step 2: LED Errors
Step 3: Add a Green LED
The green LED has the same setup as our red LED.
1. Connect the led to the breadboard.
2. Connect a 220Ω resistor to the positive(+) lead of the LED and to a Pin 5 on the Arduino.
3. Connect the negative lead to the ground rail.
Step 4: Add a Red LED
The red LED has the same setup as our blue and green LEDs.
2. Connect a 220Ω resistor to the positive(+) lead of the LED and to Pin 9 on the Arduino.
Step 5: Code for Serial Demo
Attached is the SerialDemo.ino which contains all of the code for running the binary counter project on an Arduino Uno.
