Introduction: Lamp to Speaker Tower
I couple years ago I got a lamp at a garage sale and never really used it. So I decided to turn it into some actually useful and this is what I came up with.....a speaker tower!!
Step 1: Get Supplies
First you need to get the stuff you need.
~Pliers
~Screw Drivers (Different sizes)
~Hot Glue Gun (you can use regular glue but this seemed to work well)
~Speakers
~Copper wire
~Soldering Kit
~A piece of styrofoam (you don't need it now but you might want it eventually if you want a stand for your Ipod)
~Stereo Phone Plug
~Female Crimp-on things (Got these and the phone plug at Radio Shack
Step 2: Gutting the Lamp
Before you can go in and start putting things on the lamp you have to gut it. I started with taking out the light bulbs and their sockets. Once this was done I cut off the wall plug and pull the rest of the wire out the bottom using the pliers.
Step 3: Connect Wire to Plug
So now that you have the empty shell of the lamp cut the wire to shape and connect the wire to the phone plug. I found soldering was good because it was fairly easy and pretty reliable.
Step 4: Connect Wire to Speaker
Before I could connect the wire to the speakers I had to string it through the lamp. Once the wire was in I used the pliers to pull it back out of the holes that the old wire was in. Now I was able to connect the wire to the speaker. I first connected the word to the crimp-on things, thinking that I would be able to take them off the speakers if needed. But the crimp-on things kept on falling off, so I decided to just solder the wire onto it. And that worked so I did the same on the second speaker.
Step 5: Attaching Speakers
Now it all connected so I took it for a test run and it worked! So next I put the speaker in the lamp and screwed three screw into it to hold the speaker in.
Step 6: Making Stand
The last thing I did was make a stand for my iPod out off styrofoam, using a razor knife to cut it to shape. And lastly hot glued it into the lamp.
Step 7: Your Done!!
Finally your finished it took me about 3 hours to make but you were probably faster because I was making up as I went. Now screw everything back together, plug in your iPod, and sit back and enjoy your music!!
