Introduction: Lamp in Minecraft Style!
HI! My daughter like to play in Minecraft game. So i decided to make for here a night lamp in Minecraft pixel style:)
Its very simple and easy do do DIY project.
Step 1:
You will need a few tools. I used:
- Glue
- Sandpaper
Materials that you will need:
-led light bulb
- light bulb base
- wire with switch
- glue
- wood Board 28*28 mm
Step 2:
First of all, you will need to cut lots of wood cubes. My cubes will be 28 ΠΌΠΌ. You can make any size you want. Additionally, I cut 18 mm cubes
I measured and cut, measured and cut. If you have circular saw, you can use it. It will be much more faster and evenly.
Step 3:
When we cut all cubes, we need to sand them. You can use a sand machine (it will be much more faster), or you can use just a piece of sandpaper as i did.
Step 4:
Now i will make a base for the led lamp. I made base 85*85 mm.
Then i make a first layer of my lamp. I fixed cubes with glue.
Step 5:
I waiting until the glue dries up. Then i drilled a hole for the wire. Connect wire with bulb base and fix with screws to the base.
Warning! Use only LED bulb. Led lamps do not heat up much.
Step 6:
Now i'm making all other layers. Place the cubes in any order. Whatever you like.
Step 7:
For the top of the cubes I made a stand out of paper clips. it will seem that the cubes are hanging in the air
Step 8:
That's it! The lamp is ready and you can enjoy your beautiful lamp!
I hope you like it! Thanks for watching!
Step 9:
P.s. maybe you are interested how can i removed the bulb when it will stop working:)? Please don't worry! It can be easily reinstalled in 5 seconds π
Step 10:
P.s.s If you like my project, please support me in "Hand Tools Challenge" and press button "VOTE".
Thank you!ππ€π
