Introduction: Laparoscopic Surgery Training Kit
This is a laparoscopic surgery training kit. This was the combined effort of 3 high schoolers. Hope you enjoy.
Endoscopic Camera (optional but recommended) https://www.amazon.com/dp/B071HYRPND?ref=ppx_yo2ov_dt_b_fed_asin_title
Needles for the stitching module (optional - required if you do the stitching module) https://www.amazon.com/dp/B0DCNKMCGH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Use any thread with the needle
Step 1: 3D Print All the Parts
Using your 3D printer- print all the parts. Everything should be in PLA or PETG except the trocars and the stitching module. You will print 1 of everything except the top trocars and the side trocars which you will print 6 of (top) and 2 of (side). You will also print 2 of all the parts which have forceps in the name.
Step 2: Assemble the Base
Using the main base module and the lid- slide the lid into the main base module. This should feel a little hard, but will fit in and be secure. After that- you insert the Trocars into their respective places. The top trocars go on the top and the side trocars insert into the holes on the side. Make sure you put the camera trocar in the middle top hole in the lid
Step 3: Assemble the Clamps/Scissors
Using files with custom forceps - assemble the forceps. You will need to 3D print 2 of the forceps- one for each hand. After that assemble them using the image above as reference.
Step 4: Final Adjustments
Print any modules you want for extra practice- otherwise get some small paper and practice folding origami. Other than that you have assembled the full kit. Make sure when using it, connect your camera to your phone and insert the camera in the correct spot. You will also have to print the module holder if you choose to use modules- the files for the modules and the holder labeled "module insert" are below. Be sure to print all the parts labeled TPU in TPU filament- some modules have multiple parts so make sure you attach them correctly.
