Introduction: Laptop Charger Making a Beep Sound Fixed
This was orignally published at : https://highvoltages.co/tips-and-tricks/laptop-charger-making-a-beep-sound/ visit www.highvoltages.co/blogs for more.
LAPTOP CHARGER MAKING A BEEP SOUND :
Is your laptop charger making a beep sound and it is not charging your laptop?
Do you have Laptop charger which suddenly starts making beep noises, and you want to fix it yourself?
Then you are at right place. In this tutorial, I am going to tell you how do I fix this problem and how you can do it yourself.
INTRODUCTION:
You are already familiar with the definition of the charger and its importance. If for some reasons your laptop is not charging your laptop and is making beep noises then it is the matter of concern.
There can be many reasons for which charger can make beep noises and not charge your laptop properly. I am going to explain few with solutions.
Step 1: POSSIBLE CAUSES FOR LAPTOP CHARGER MAKING BEEP NOISE WITH SOLUTION:
AC ADAPTER LOOSE WIRE:
We are already familiar with AC adapter which converts AC Voltages into DC Voltages as our laptop needs DC to be charged but if for any reason the AC cord is loose and the AC adapter is not getting proper power it can make beep noise.
The solution for this is to make sure that your AC cord is connected properly and your AC adapter is functioning properly.
FAULTY ELECTRICAL SOCKET:
Another reason which can troubleshoot quickly can be the fault in the electrical socket. Due to which your AC adapter will not get power properly and hence can make bee noises.
The solution for this I to make sure that your AC adapter is connected properly with the socket or try changing the socket.
SHORT CIRCUIT:
Another reason, which was the main reason why my laptop charger was making beep noise is short DC circuit.
If you carry your charger in the bag and the wire is folded often then this can be your problem.
The solution for this is to open your charger and check for the shortage using a multimeter and solder it properly and make sure the DC + and DC – are not touching each other.
Step 2: Watch This Video, That’s How I Fixed My Charger Which Was Making Beep Noise Due to Short Circuit.
Step 3: Conclusion
The above method can help you fix your charger if still, you are not able to fix it, i will recommend you to buy a new charger. You can buy a new charger from here.
Follow us on youtube
