Introduction: Laptop Controlled Rgb Led V.1
hello tech buddies,i have been into project making hobby since i was a kid.the instructables site has catalysed this hobby and i am very greatful to all the publishers.
This is my 1st one,and i request you to do the two things:-
1)support me
2)pardon my mistakes
coming to the instructable,i'll show u how to control a rgb led via laptop.
Step 1: Materials Required
1) an arduino board(uno r3 in my case)
2) common cathode rgb module(if u dont have a module, u can do it with the rgb led with 220 ohm resirtors connected to ur common cathode rgb led)
3) connecting cable
4)jumper wires
4)and ur laptop.
Step 2: Ahh... Procedure
as the name suggests these leds can give out red/green/blue lights.
our intention is to make the led to give out color for respective alphabets entered in our laptop keyboard.
r --> red
g -->green
b -->blue.
connections:-
connect ground terminal of led to ground of arduino
connect red terminal to digital pin 5 of arduino
connect green terminal to digital pin 6 of arduino
connect blue terminal to digital pin 7 of arduino
Step 3: Code
copy and paste this code on ur arduino sketch:
//coded by manoj surya k
//there is always room upon improving the code
const int red = 5; //declaring led pin
const int green = 6;//declaring led pin const
int blue = 7;//declaring led pin
int incomingByte = 0;//declararing incomingbyte variable and initializing it to zero
void setup() { // put your setup code here, to run once:
Serial.begin(9600);
Serial.println("press r for red color,g for green color and b for blue color");
pinMode(red,OUTPUT);//declaring output
pinMode(green,OUTPUT);//declaring output
pinMode(blue,OUTPUT);//declaring output
void loop() { // put your main code here, to run repeatedly:
if (Serial.available() > 0) { //check for byte
incomingByte = Serial.read(); //read the byte
switch(incomingByte) //control for various cases
case 'r': //if r is typed
digitalWrite(red,HIGH); //red glows
incomingByte='*';
break;
case 'g': //if g is typed
digitalWrite(green,HIGH); //green glows
incomingByte='*';
break;
case 'b': //if b is typed
digitalWrite(blue,HIGH);// blue glows
incomingByte='*';
break;
delay(100); //wait for 100ms
Then go to the serial monitor and control ur led.
thank you,support me and many more comin up.
