Introduction: Laptop Cooling Stand From Cardboard
Hello,this is my First Instructables.I have made a Laptop Cooling Stand from Cardboard which I got from old Fabric Packet.This also has a BLDC Fan for Cooling and proper ventilation of laptop.This stand can be mounted at various angles for different viewing angles with help of 4 brackets.
- Cardboard
- BLDC Fan-(you can get inside a cpu or online)
- 9V Battery
- Cutter
- Fevicol or any Adhesive
- Paint(Optional)
Step 1: Making Base Structure
First Measure and Cut the Cardoard according to size of your laptop.
I have Bent the Cardoard to Give it a 'V' Shape.
Also Cut a Circle for installing the Fan.
Step 2: Making the Brackets
I have cut two 10*10cm and two 10*5cm cardboard rectangles.
Then I increased the thickness by Bending it and Gluing it.
Step 3: Cutting the Brackets
Take the Cutter and Cut the sections accordingly so rackets can fit inside the Main Cardboard Structure.
Step 4: Add Laptop Limiter
Add a 4*30cm limiter to Stand so that your laptop won't slip from stand.
I just Glued it to Main Structure.
Step 5: Install the Fan
Place the fan in the Cutted Circle and Glue it.
And Glue 4 Spacers(4 small squares of Cardboard) at corner of stand so that laptop has a ventilation.
Step 6: Attach the Brackets to Stand
Attach the brackets to the stand According to your Viewing Angle and On the Fan.
So your Adjustable Laptop Cooling Stand is Ready.
Step 7: Paint the Stand(OPTIONAL)
So paint the stand with your Favorite Color.
