Introduction: Laptop Hologram
This project is made for the TfCD course of the IPD master of Industrial Design Engineering (TUDelft).
Introduction
This instructable shows you how to make a hologram for medium sized screens, laptop and small desktop screens for instance. The model we will be making uses reflection to create a hologram image. Four images our movieclips displayed on your screen will be reflected into a holographic 3D image inside the transparent pyramid. Because of this, the hologram model only works in a dark room.
What do you need?
- Ruler
- Pencil/Pen
- Painting tape
- Plastic glue
- Snap-off blade or cutting machine
- Transparent plastic sheet (285mm x 210mm)
Step 1: Create Building Plan
Draw the construction of the 4 sides of the pyramid on the plastic sheet
(We used a sheet of 360mm x 210mm so we had some margin on the sides, which are not necessary).
Step 2: Cutting
Cut the plastic sheet to end up with the 4 sides of the pyramid.
Step 3: Tape and Glue
Use painting tape to connect the 4 sides of the pyramid, then use the plastic glue for a permanent connection.
Step 4: Finishing Touch
Remove the painting tape and clean the pyramid of dust and finger prints.
Step 5: Use the Hologram
Search on YouTube for: Hologram video
Put the video on full screen and place the plastic piramid, with the small surface down, in the middle of the screen.
