Laptop Stand for Your Netbook
Intro: Laptop Stand for Your Netbook
Most laptop stands are made for full sized laptops.
I looked forever for a suitable stand for my collection of Eee Pc netbooks. Everything was either too big, too expensive, or just plain didn't exist. Eventually I headed off to my favorite store - IKEA - to look for a solution.
A couple of hours and a few dollars later I had my solution.
This instructable is made for a netbook. It will work with most netbooks up to 10 inches in size. It is constructed with 2 plastic shelf brackets, 2 drawer handles, a couple of telescopic bolts (optional) and and cabinet screws. Basic tools such as a miter saw, a snap-off blade knife, and a screwdriver are all you need to complete the project.
STEP 1: The Parts
Here are links to the Ikea components:
Stodis Shelf Brackets http://www.ikea.com/us/en/catalog/products/30167461
0.50 each
Attest Handles http://www.ikea.com/us/en/catalog/products/90038541
$3.99 a pair
You can also use any other style 4 to 5 inch handle. Just remember that you'll need 2.
One pair of screws that come with the handles and one pair of half inch screws. If you use Ikea components you'll need to make sure to the smaller pair is in metric size.
Optional: one pair of 5/8" telescopic bolts just to cover the unused hole and make everything look extra sweet. Not necessary. http://www.awt-gpi.com/product75.htm
A saw. You can use a dovetail saw, a miter saw, a jig saw. Whatever you have access to will probably work just fine.
Sandpaper and a sharp knife for cleaning up the edges.
Screwdriver.
0.50 each
$3.99 a pair
Screwdriver.
STEP 2: Making the Pattern and Cutting the Brackets
I traced one of the shelf brackets onto a piece of sturdy paper, cut it out, and used it to and then cut one end down until I arrived at the right height. for the stand.
From there it's pretty straightforward. Mark each bracket and cut.
Trim any extra bits away and sand off any rough edges.
STEP 3: Assembly
Easy as pie.
STEP 4: Using Your NetBook Stand!
I use the stand when I want to work with a full sized keyboard or if I want to raise the screen a little higher for watching videos, etc.
25 Comments
DIYfan 6 years ago
Really nice - simple, cheap and functional. It's fairly interesting looking as well. I have way too many laptops, including three Chromebooks. It's a pain to think of putting $60 into commercial stands. This looks like a viable way out of that .problem.
bertus52x11 8 years ago
This is very nice! Great idea!
kathleenhenri 12 years ago
Thanks everyone!
Da_huuudge 14 years ago
Rich99 14 years ago
kathleenhenri 14 years ago
RDuran 14 years ago
Tape-structable 14 years ago
Xamu 14 years ago
1) take a single bracket and cut it at 45° at the corner making two identical half brackets. (A hack saw will probably provide cleaner results than a typical hand saw for wood. Just take your time and focus on making it look nice.) Sand the cuts lightly to remove sharp edges and for appearance.
2) drill and mount the shelf supports as previously described
3) mount the drawer handle to join the two half brackets at the thicker end as previously described
Voila! The attached drawer handle becomes the elevating support.
If the angle is too low now, use a bunch of washers (as spacers) and either longer drawer handle screws or threaded rod & nylon lock nuts to adjust the angle.
Also, if you wanted to do this for a larger laptop, you could use a wider handle, such as Ikea's LANSA handle http://www.ikea.com/us/en/catalog/products/60138759 which comes in 10 1/16", 13 7/8", 21 7/16", and longer.
Good idea! You are to be commended.
richelton 14 years ago
Chromatica 14 years ago
isacco 14 years ago
ScottSEA 14 years ago
biggy smalls 14 years ago
